Spice up the engine
Old Apr 24, 2003 | 02:20 AM
Rustyd2k2's Avatar
Spice up the engine
Im looking for some things to spice up the speed for my 3.1 90 camaro RS. I dont wanna swap a engine, Just something to give me a bit more hp. Any Ideas??
Old Apr 24, 2003 | 09:35 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Open the intake, and Dynomax catback exhaust... that's where I'd start.
Old Apr 24, 2003 | 10:12 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Re: Spice up the engine
You ask us what to do- sso we have to ask you the age old question "how much money do you have to spend?" Are we talking $50 or $5000?
Most important question is "do you intend to keep this car/motor or would you buy something else if you had the money" You'll never get your money back out of it if you intend on selling it.
Old Apr 24, 2003 | 10:25 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
agood, as rude as that sounds, your 100% correct.
What do you want? How much power do you expect? How much money you have to spend?? Do you want top or low end??
Old Apr 24, 2003 | 01:04 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
If you're like I was....on a very low budget and saving up between modifications, with the intent of keeping the car with the full realization that it's still not going to be very fast....here's what I did...I think it's a reasonable order for the money-minded.
Intake: There are several ways to go. Most prefer to build an intake out of PVC tube with a conical filter on the end. You have a 3.1 so it's extra easy. Just remove the intake 'arm' by loosening the two screws, then take the big bolt out of the middle of the filter canister holding it down. Disconnect the sensor connector from the side of the can, and using a wrench and some serious arm strength, screw the sensor out. It might take some liquid wrench and the assistance of, say, Arnold Schwarzenegger. I just got this big guy named Tony. I'm not kidding either! Remove the can. Reconnect the sensor you removed to its connection. Place it somewhere NEAR the filter and tape it down. As long as its reading is close to the actual air temperature going into the filter, you're fine. Now, get the PVC and filter, and start building! Use the original flextube...it's too much hastle to try to build something without it. Or if you wanna half-*** the whole intake..just drop in a K&N replacement filter. But the difference will NOT be that big, I'm warning you.
Exhaust: Summit Racing. Dynomax Super Turbo catback. $155 if I remember right. Comes with all piping past the catalytic converter, and includes the Super Turbo muffler. The piping is 2 1/2 in., as opposed to stock 2 1/4 in., and is mandrel bent and stainless steel. Stock piping is badly crimp bent. This mod will give an exceptional amount of power. Cars who would beat you before by a car length, you should now be able to beat. I know..I did on my old car. (3.1 auto) Fair warning...the catback does not come with tips, just the ugly muffler exit pipes with their own "tips"...but they ARE extremely ugly, so if you want the "bling bling" factor, buy some tips when you order the catback. I got the Edelbrock chrome angle-cut intercooled 3 1/4 in. tips.... They looked great, but were pricey at around $30-$35 each.
Ignition: *New plugs - (DON'T BUY SPLITFIRES! And you can experiment yourself with the Bosch Platinums...there have been both positive and negative experiences here on the boards. Dont buy the +2's or +4's though..WASTE OF MONEY.)
*New wires - Don't overspend...you arent gonna see extra power out of them unless the old ones were junk. However, 8+ mm wires are the better choice..7mm's are wimpy stock stuff. You can get a set of Taylor SpiroPro 8mm wires, which are very well built wires, for between $50 and $60 for a custom set. And they're available in any color you could ever want.
*New cap and rotor - Just get a blue streak one or something...just make sure it has brass terminals. If your old cap and rotor was only 'ok', replacing it will make quite a big difference! You'd be surprised! That's like $20.
*New coil..optional.. Check it to see if the spark color is ok. White = good. Blue = accceptable. Anything else = too cold.
I recommend an MSD Blaster GM HEI direct replacement coil. Accel and Hypertech also offer direct replacement units. Matter of preference.
There's my essay. Have fun with it!
Old Apr 24, 2003 | 02:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL!
Also, as far as spice, you can apply the ideas above with the major tuneup post of mine. Remember if your motor's not running well, you won't see the most gain possible from mods. <A href="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=162251" target=newwin>Click here for the tuneup message.</A>
Old Apr 25, 2003 | 02:36 AM
Rustyd2k2's Avatar
Thanks guys, that is alot of help. And i am looking for more cheep and i do wanna keep the same motor. Yea that will be alot of help to me, im trying to get up with the Iroc's, Its kinda funny when a iroc trys to talk trash then you smoke him with your 3.1L V6 that should shut them up.
Old Apr 25, 2003 | 02:39 AM
Rustyd2k2's Avatar
And Nixon1 is that your car on your icon??? cuz thats funny it looks exactly like mine color and all. I just got a paintjob on it and fixed the EGR valve, and im looking for some 95-96 Camaro Seats for it. And im gonna do those mods that you said cuz i am saving mod by mod LOL thanks
Old Apr 25, 2003 | 02:56 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I would do the tune up like Tom P said but if you end up doing the tranny fluid if it hasent been changed in a while or is burnt it would be best just to leave it alone it MAY cause your tranny to go. If you do decide to do it use Valvoline Max Life ATF fluid works well.
Mod wise i would start with the intake if you dont have money to make a CAI just take off the air silencer on the air box and cut some of the metel off along the sides that will work thats what i did before i did the cold air intake. If you do a cold air intake go to autozone and look up a filter for a newer chevy trunk disel it is a hudge open element.
Then i would put a crank pully on the car it will be smaller and you will gain HP and get more MPG so you can save for more mods that runs 50 bukcs plus a new belt.
Then go with a nice exhaust and high flow cat.
Then msd box and coil and you will have a replica of my 91 3.1 camaro except i have a chip in mine. Dont forget to change the O2 sensor.
Old Apr 25, 2003 | 02:32 PM
Rustyd2k2's Avatar
Yea im trying to learn as much as i can about intakes, cause i dont know **** about them. So alot of the stuff yall are saying i dont understand but im trying!! haha can someone explain to me what to do with my intake in retarded turms?? haha Sorry for the truble and thank all o yall or yalls replys.
Old Apr 25, 2003 | 03:05 PM
Dale's Avatar
Engine: 350 S-TPI
A "cold air intake" is basically just opening up the flow, and removing any restrictions. Most of them don't suck in real cold air, just less restrictions. So basically, anything that looks like it restricks airflow, try and find a way around it. Except the air filter itself.
Fast Rs is talking about that little round canister in the right front of the engine bay that the air tube goes it. He is saying cut about half the sides off of it. This is a cheap fast way w/o buying any parts. Some remove that whole canister, and just attach a cone (euro style) air filter to the plastic tube and are done with it. Others create them from pvc tubing, aluminum dryer ducting, all sorts of stuff. Just rem, less restrictions, the better. Anywhere you can direct it to get cold air, but no water, the better.
I installed a older camaro v8 TPI air intake. Looks stock, does its best to get cold air in.
On a sad note, I "doubt" you will beable to hang with irocs. However, I bet you could give them a nice surprise.
Old Apr 26, 2003 | 12:29 AM
Rustyd2k2's Avatar
Are the v8 TPI air intake's as good as disconnecting the intake or building one with pvc pipe?? is it better?? and is it easy to install?
Old May 8, 2005 | 12:46 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
if you have a camaro they're easy to put in, firebird then you have to build your own.
Old May 8, 2005 | 06:21 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
serious power
if u want alot of power out of a 3.1 get pacesetter headers/ y-pipe and one of amcamaros custom plenum/tb. And or nitrous
Old May 8, 2005 | 10:43 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
did the Y shaped intake not come on V6s? My car came with one and mine has an IAT bung that my friends IROC doesnt have. I just gutted my intake and will be putting it on soon
Probally goanna do a ram air with it too. I like how its outside the engine bay
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
