OH no please help me!
Old Apr 24, 2003 | 02:06 PM
icebird_1981's Avatar
well i have a problem and need your guys info before i thouch it. k i am leaking red fluid and i think i pin pointed it to a line going in my rad on the bottom right were it has the creaw the crew is covered in red fliud. well like a burgendy colour. help me out what is that line from? and what is in?
Old Apr 24, 2003 | 02:09 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
red fluid is one of 2 things. It's either Trans fluid if you have an auto, or it might be from the Power steering. I think the P/S unit uses auto trans fluid. Thoses are the only 2 things I can think of that use red fluid. Probably P/S pump or lines leaking, unless you have a trans cooler.
Old Apr 24, 2003 | 02:49 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
That would be automatic tranny fluid. Power Steering doesn't go near the radiator, esp on the pass side of the bay.
Power steering takes power steering fluid, not dextron 2-3-4. Or I have yet to see one that does.
You can try and carefully tighten the nut as it is prob made of aluminum and could strip easy.
Old Apr 24, 2003 | 02:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've heard of people putting automatic trans fluid in their power steering- but I don't think I've heard of people on thirdgen.org doing it. It might be a ford thing?
I just wonder how that line got loose, icebird... were you doing any work in that area recently? Check the level of your automatic trans fluid, hopefully you didn't lose a bunch... but you should check anyway. You don't want to run low on trans fluid. Remember to check it with the fluid hot and the engine running (stick in Park, with the wheels blocked).
Old Apr 24, 2003 | 09:18 PM
well i dont no how it came loose i was not doing anything over there, but i am going to try to tighten it fist thing tomorrow and i checked my tranny fluid and it was low so i did not drive her today, went and got some fluid first. (play it safe)
Old Apr 25, 2003 | 05:57 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If the fluid had a brownish tint to it, it may be time to change it and the transmission filter as well. Just a thought.
Old Apr 25, 2003 | 09:25 AM
DaGoat's Avatar
It's not just a ford thing, I've seen it done on many makes and models. Fords do have alot of problems with power steering though, and the tranny fluid helps some of them.
Old Apr 25, 2003 | 11:10 AM
pontiacguy1's Avatar
sorry, my computer had a brain fart... or would that be a board fart?
Old Apr 25, 2003 | 11:12 AM
I have used Tranny fluid in the power steering pump of several of my vehicles in the past. They have similar fluid properties and are about the same viscosity. Tranny fluid also costs about 1/2 what power steering fluid does. I have used it in my Toyota truck, both when it was a toyota 4 cylinder, and after converting it to a V8, in my old farm truck, and even in my Ford 6600 tractor. I have never had a problem using it in anything of mine.
Old Apr 25, 2003 | 02:11 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
My old Mazda used ATF in the P/S, so I thought it would be a good guess. Never changed the P/S fluid on my car...probably should at this point though.
