converter q.
Old Apr 30, 2003 | 11:48 AM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
converter q.
uh, what if i just replace my converter with a straight pipe? what would happen if i did that? thanks...
Old Apr 30, 2003 | 11:55 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Depending where you live you wouldn't pass inspection.
Old Apr 30, 2003 | 12:20 PM
Engine: 2800
i knew that........how much of a performance/sound difference would it make???
Old Apr 30, 2003 | 01:35 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Are we talking your stock cat? You'll see a small performance gain with it because your stock cat was probably old and not flowing decently. Sound volume should go up quite a bit. My buddy has a Fiero with a deleted cat and the sucker is loud as hell.
Old Apr 30, 2003 | 02:44 PM
pontiacguy1's Avatar
Having a straight pipe will only give a couple of HP gain over a new High Flow catalytic converter at the most. You will pick up some power swapping out your old factory one, though.
The best advice I can give you is to buy a high flow cat and put it in place of the factory one. That way, you get the HP gain and it is legal, which can be a big deal depending on where you live. It can also be a big deal if you ever try to sell the car. It will cost a little more, but I think that it is worth the money.
Old Apr 30, 2003 | 03:05 PM
Engine: 2800
ok, so what kind of a CC do you sugest? prices? thanks for your responses guys
Old Apr 30, 2003 | 03:46 PM
I think that you can get a Catco 2.5 inch inlet/outlet converter for about 100 dollars or maybe even less. That is what I have in my car, and the whole thing is about a foot long. It also weighs a lot less than the factory one.
Old Apr 30, 2003 | 05:07 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
You'll gain some top end power and add rpm range. Stock cats flow fine until about 3500-4000rpm's
Old Apr 30, 2003 | 07:10 PM
Engine: 2800
so..... strait pipe.... or aftermarket CC? cuz ive got some money for an after market, but i sure would save some $$ if i just put the pipe on.... also intrested in Y pipe, not sure how to do one of thoses set ups... Again, thats for the feedback...
Old May 1, 2003 | 10:23 AM
Like I said in my above post, there is no way I would advise you to put a straight pipe in there. It won't be smog legal, and you may have to fix it if you ever try to sell the car, depends on the laws in your state. It also won't gain you any noticeable HP over a good high flow catalytic converter. Just for the sake of knowing it is legal, you should put the cat in there. Get another Y pipe made, get a high flow 2.5 inch cat, and a catback exhaust system, and you will have a great exhaust for the V6.
Old May 1, 2003 | 11:15 AM
Engine: 2800
....thanks....
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
