Backfire woes...
Old May 6, 2003 | 08:08 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Backfire woes...
Had some arcing... replaced the wires. Backfire is still there - #6 cylinder it seems. When it pops, too, I can see some smoke drift up from where the egr blockoff plate is, and near the exhaust. Would an exhaust leak cause a backfire? I know the car is running a bit rich as it is...
Old May 6, 2003 | 08:39 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Exhaust leaks will cause backfires and misfires, depending...
Old May 6, 2003 | 09:48 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I would say try adjusting the timing a few degrees, clamp it back down and take if for a drive. See if that changes anything. I know my car would not run great at at 10*, but would run better adjusted some. I see you have adjusted, but maybe you need to set it back or up some.
Second, EGR it can cause a lot of problems, I would really check into that.
Third, your exhaust leak and running rich could be a bad combination get those checked out.
Old May 7, 2003 | 12:35 AM
Doward's Avatar
I don't have EGR. What I have, is a bad case of working on PMD engines too damn much!
I set the #1 cylinder as the driver's side front. Needless to say, IT'S ALL WRONG. Jesus freaking ..... grrr!!
Tomorrow I'll tear it all apart, and do it the right way - #1 cylinder is the front passanger side, for anyone that wants to know.
Old May 7, 2003 | 09:53 AM
Doward's Avatar
PMD and Chevy are not the same. All fixed. She's rev-happy again!
Old May 7, 2003 | 01:08 PM
Nixon1's Avatar
What does PMD stand for? Never heard that abbreviation before..
Old May 7, 2003 | 05:23 PM
Doward's Avatar
Pontiac Motor Division.
Basically, the REAL Pontiac motors (pre '81 - or pre '79 for you 301 haters out there )
Old May 7, 2003 | 08:58 PM
Nixon1's Avatar
Gotcha... Not too familiar with the old-school stuff....
Old May 7, 2003 | 10:46 PM
Joe_L's Avatar
Car: 1995 Z28
Good to see you figured out your problem. So let me get this straight you were timing your car from your #2 plug, but you thought it was the #1 right.
I can see why your car would problems running.
Anyway great to hear its fixed.
Old May 9, 2003 | 06:53 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
check your egr valve. mine had a broken screw and it would backfire between the egr tube and the valve. also saw a puff of smoke when it happened. feel all around the egr, if theres a leak you'll feel air pulsing out.
Old May 9, 2003 | 09:36 AM
Doward's Avatar
lol, sorry, problem fixed. And... I have no EGR anymore
Yeah, I was timing off #2. Jeebus! Wow she's a rev happy little engine now
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
