Underdrive Pulleys - Belt size
Old May 7, 2003 | 12:39 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
About a year ago I purchased underdrive pulleys for my 3.1L. I never installed them becuase I always heard rumors of charging problems and such. Well it's come to the point that I want to get some more performance, and since I already bought them, they are sitting in my room, I want to put them on.
I heard just replacing the cranky pulley is better then doing both the crank and alt that the kit came with. The pulleys came with a piece of paper telling me which belt size I need for the two pulley setup. I did a search, and I didn't get any real results back, so that's why I'm here to post about this. Maybe I just don't put in the right words when I search or something...
But anyhow, I want to put the crank pulley only on my car and I don't know what length belt I will be needing. If any of you guys know the size or heck even the part number I would really appreciate it! Thanks a lot!
Old May 7, 2003 | 01:07 PM
DaGoat's Avatar
I don' t know the answer to your question but if no one else chimes in you could use a piece of string to see how long of belt you need. Just wrap the string all the way around, then take it off and measure. Parts stores should have just about any length.
Old May 7, 2003 | 01:36 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
the chrging problems could be due to not changing the alternator pulley. it has to be in the kit for a reason and im guessing(i could be wrong tho) that its there to avoid chargin problems
Old May 7, 2003 | 02:29 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
go to aspracing.com, they have a belt sizing chart on their site.
However, I have a crank only and got a .5" size smaller belt then they listed.
so says its 060755 (75.5") I got a 060750 (75.0") *size for reference only*
Old May 7, 2003 | 02:39 PM
Engine: 346ci LS1
Transmission: MN6
Thanks for the info!! May I ask what made you go for a smaller belt? Was it just for good measures? Thanks!!
Old May 7, 2003 | 08:39 PM
Dale's Avatar
Engine: 350 S-TPI
The tensioner was almost to its outter limits when on, so I went that tad smaller. It "could" have gone full inch, but didnt want to push it.
So it was for "safe measure"
Old May 7, 2003 | 11:38 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I had a charging problem with mine so i just used the crank pully email me if you need the belt size for your car what years is yours i hae a 91 with a 3.1 AC smog pump P/S and all that crap.
Old May 8, 2003 | 09:49 PM
V6camaroman's Avatar
hey guys i still have my asp crank pully sitting in my garage and i never knew what lenght of belt to get. so on my 87 firebird with AC i need a 75.0" belt? if im only running the crank pully and i have AC and no smog pump.
Old May 9, 2003 | 12:39 AM
FAST RS's Avatar
Here is what you do. Take a string run it around all the pullys like the old belt was routed. Then measure how long the string is in inches. Then go to the store and say you need a belt this length in a K6 and there ya go.
Old May 9, 2003 | 06:55 AM
Dale's Avatar
Engine: 350 S-TPI
or go to aspracing.com like I stated in my above post, look at their chart, then get a .5" smaller belt.
Old May 9, 2003 | 11:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: Underdrive Pulleys - Belt size
LOL! That's my attitude; take advice for what it's worth, and try it anyway. Either way, it winds up being proof (and a learning experience!) for some part of the yes/no argument! Let us know how it goes!
Old May 9, 2003 | 01:36 PM
BitchinRS's Avatar
Don't worry about charging problems. As normal, if your Alt. is in good shape you will have no problems. I have both the crank and alt pully installed for the past 45,000 miles and not one problem. When I am at idle the charging drops a bit, but once I start doing 2MPH it goes back up to normal. BTW: this is with the radio, stero, high beams, and the dome light on.
The low charge at idle is by design. With both the crank and alt pully full charge doesn't happen till 11,00 RPM. How much time do you spend bellow 11,00RPM? If you drive like me the answer is, as little as possible!!
Galaxie500XL
Feb 1, 2020 04:53 AM
BDR
Nov 7, 2015 03:05 PM
iroczguy86
Sep 13, 2015 02:22 PM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
