Engine Prob. Idle.
Old May 8, 2003 | 08:22 PM
88camarov6's Avatar
Car: 87 Camaro Vert
Engine: Cammed LT1
Engine Prob. Idle.
Ok heres my prob. Whenever I *try* to start my car, the engine will start up, run for about 2 seconds and then die like its getting no gas. Even if I floor it or just give a lil gas, it will still die. I let the fuel pump engage and I just fixed hose going from a sensor on the upper right valve cover (looking head on) that causes the car not to run at all. (I forget what the sensor is right now). I start the engine, it dies. I go through this cycle about 10 times, untill it runs for just long enough to put it in drive or reverse and go. Once the car has driven for even under a minute it will idle fine. Ive tried adjusting the idle speed which helped. Is it my fuel pump, becuase that's gonna be a pain in the ***. Sorry for the long post, but I'm really frustrated. Going over all those vacume lines and whatnot in the rain is really really annoying.
Old May 8, 2003 | 08:31 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
sounds like IAC.... it's getting gas - just not enough air to keep running.
Old May 8, 2003 | 08:40 PM
88camarov6's Avatar
Car: 87 Camaro Vert
Engine: Cammed LT1
Thanks, Ill check that out tom. Come to think of it, I broke the little snap on thing.
Wade787b
Sep 29, 2015 01:15 PM
Logan Bryant
Aug 27, 2015 11:52 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
