3.4 power
Old May 11, 2003 | 10:00 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
3.4 power
Ok here it is. With a 3.4 how much power will I make with 1.6:1 roller rockers and a performance cam (if there is such a thing for the engine). And where can I get them (links please). Thanks
Old May 11, 2003 | 11:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you can get bigger cams for the 3.4, from either crane or comp cams. They each make 1/6 rockers also, just depends on whether you spend $110 for roller tips, or $300 for full rollers. Jegs, P.A.W>, summit, etc.. all carry these rockers, just have to call up & ask for it.
btw, the stock 3.4 cam is the same as the crate motor & H.P. replacemetn in the GMPP catalog.
Old May 12, 2003 | 01:20 PM
Soft Taco2's Avatar
well desktop dyno reports right under 200hp with the crane powermax 2030
http://cranecams.com/master/apps/chevy1.htm
EDIT: Thats BHP not RWHP.
Old May 12, 2003 | 02:34 PM
What would the difference be between full rollers and roller tips.
If I were to get the powermax 2030 cam would I need to get all those other valvetrain components that they list or are those just suggested accessories.
Old May 12, 2003 | 02:40 PM
KED85's Avatar
IF ya spend the MEASLY $6.95 by going to ANY GM DEALER to obtain the
GM PERFORMANCE PARTS BOOK
Examining the 60* section you'll find the 3.4 mill & the GM cam up grade for the 2.8-3.1.
That cam is the CRANE 203 as CRANE made/makes it for GM.
THE ONLY WAY you'll get this 200 HP is thru lots of contacts for exhaust & air inlet people.
Serious
The BIGGEST 3.4 power restriction is the factory only option street legal exhaust set up allowed.
CLUE
the 3.4 exhaust "Y" pipe from the 1993-95 FBODY is a great upgrade provided ya tweek it for better fit.
I know that's what I'm doing.
HOW MUCH FACTORY HP
Brochure say 160-165 HP & 200 FOOT POUNDS OF TORQUE
AND I LOVE BIG NUMBERED TORQUE!
THE BEST WAY to get the best HP under hood is to go BRAND NEW
NO ONE YET has done a 3.4 CRATE ENGINE SWAP BOOGIE!
All us have done used running mills from the $ range of $210 to $800/$900 (last two $$ my costs).
I buy low milage 3.4 mills (44K & 50K).
NEW is $1800
Can't purchase parts, 3.4 engine & machine labor for the $1800!
BARGIN!
Good luck with your choices
I highly recommend this 3.4 option to everyone who TRULY LOVES THEIR CAR & can afford the $$ for the effort.
3.4 SWAP BOOGIE IS SO WORTH IT!
Old May 12, 2003 | 03:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Still working on my 3.4l swap!
Its nice, has a few bugs to work out.
If I could only figure out how to extract trouble codes from that style pcm
Old May 12, 2003 | 03:04 PM
Soft Taco2's Avatar
Serious
CLUE
HOW MUCH FACTORY HP
NEW is $1800
BARGIN!
meh, 350 > *
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
