Swapping to a 4th gen rear...
Old May 17, 2003 | 01:35 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I'm gonna go get that 4th gen disc rear end from the boneyard. 3.42 gear, LSD rear end.
What will I need to pull my rear end out (done it before) and stuff this one up into it? I'm getting the rear end for $125, so I figure it's worth it just for the LSD.
I guess I should say... what do I need to make it work?
Old May 17, 2003 | 04:38 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
nothing, bolts right in as if it was supposed to be there
might need parking brake cables, yours might work though
Old May 17, 2003 | 05:42 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
and you'll need a new proportioning valve, try to steal it from the same car you get the rear out of.
Old May 17, 2003 | 06:28 PM
bes217's Avatar
aren't the fourth gen rear wider than our thirdgen's?
Old May 17, 2003 | 07:13 PM
Doward's Avatar
Yes, they are. About 2" I believe.
Ok, need the prop valve, np there. And the ebrake? Being a stick, I will want that!!
Old May 17, 2003 | 09:16 PM
see how your brake balance is with out the valve first
mine was right on the money (without the prop valve) and so were others that i talked to on this board
Old May 24, 2003 | 01:59 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
I'm lookin for a 4th gen rear, If I go to a bone yard, what do I search for, how do I know it is 3.42's. Which models had those? or what rpo code do I look for? or is it stamped on the rear end case?
Old May 24, 2003 | 09:12 PM
take off the cover and count
Old May 25, 2003 | 01:44 AM
BitchinRS's Avatar
Call me a dip but what should I count. I don't know much about reare ends.
Old May 25, 2003 | 08:14 AM
the number of gear teeth
Old May 29, 2003 | 10:56 PM
IndyTruck's Avatar
Hey, do they have another one? I'd drive to Ocala for that!
kevin
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
