3.4 hp/cam specs
Old May 17, 2003 | 06:50 AM
E-Z Rollin's Avatar
3.4 hp/cam specs
Anyone know the stock hp rating for a 3.4 in a firebird or camaro ? howabout cam specs?
Old May 17, 2003 | 09:25 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
160hp, 200ft/lbs, stock 3.4
Old May 17, 2003 | 12:51 PM
E-Z Rollin's Avatar
Which is the same as the 3.4 crate motor but doesn't the stock 3.4 have weaker cam specs,why the same hp?
Old May 17, 2003 | 01:07 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
The HT3.4 GM crate motor is the same exact motor that came stock in the '93-'95 60*v6 Camaros. Gm lists it as a high performance upgrade for the older 2.8 S10 trucks
Cam lift is .427"I/ .454"E w/ 1.5 rockers
Old May 17, 2003 | 02:32 PM
E-Z Rollin's Avatar
Thanks, for some reason I thought they had different cams.
Old May 18, 2003 | 06:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The 3.4l crate engine, and the 3.4l camaro engine do have different cams, and are different part numbers. I checked that thursday after work.
The crate cam is designed for low end tourqe, where the camaro cam is designed for mid range horse power.
Old May 18, 2003 | 06:15 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Dale, do you happen to have the cam specs on the Camaro 3.4 then- I've obiously been given bad info- I was told it is the same exact motor.
Thanks, Dean
Old May 18, 2003 | 08:18 PM
Dale's Avatar
Engine: 350 S-TPI
Crank, pistons, are the same.
Block the only difference is the camaro motor is machined for cam sensor.
As for cam, the crate is designed for carb, and tourqe. S10 board uses it for TBI's still, unsure if anyone has put multiport on it.
I do know for a FACT, the part number is different.
This is what I was given on crate cam.
204/216 @ 0.050, .427"/.454"(w/1.5), 107 lobe spacing, 107 ICL, 107 ECL
Old May 19, 2003 | 12:33 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
I can confirm the specs on the HT3.4/ they are correct ( thats the same specs I've had). What I can't find is the specs on the stock 3.4 Camaro motor's cam.
What I can confirm from tonights research is:
GM performance crate motor- HT3.4: 160HP @ 5000rpm/ 194ft lbs @ 2700rpm
Stock 3.4 Camaro crate motor-(Don't have part #?): 160HP @ 4600rpm/ 200ft lbs @ 3600rpm
With those dyno specs, they definately have different cam grinds
Question now is
1) What is the part # for the stock 3.4 Camaro longblock?
2) What is the cam grind specs for that motor?
Old May 19, 2003 | 06:58 AM
Dale's Avatar
Engine: 350 S-TPI
I did some searching on here after I posted that, and found the specs, the same But I left it at home , but the specs are on here, and they are the same. Strange.
I know on my s10 board (s-series.org) they say the cam for the crate is very tourqe. And the one for the camaro is high rpm and "weak" in their eyes.
Old May 19, 2003 | 09:15 AM
Dale's Avatar
Engine: 350 S-TPI
Think I found it http://www.f-body.org/tech/tech.htm
10168531 lift .450/.460 duration 203/208 and lobe sep of 116 (114/118)
Old May 19, 2003 | 08:51 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Thats not it, thats a 5.7 V8 cam spec for F-bodies and Y-bodies in '94. Y-bodies are Vettes and as we all know did not have V6's
Old May 19, 2003 | 08:54 PM
Dale's Avatar
Engine: 350 S-TPI
stupid me.
I did find some specks on this site somewhere.
Try a posting buy linuxguy titled "thinking of cams" on 1-20-03
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
gord327
Oct 3, 2015 01:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
mfp189
Sep 27, 2015 09:25 AM
wstephan96
Sep 25, 2015 04:28 PM
