rear seat?
Old May 23, 2003 | 11:52 AM
confucius101's Avatar
rear seat?
simple yet stupid questiong for ya
how do i remove the rear seat from a 91 firebird????
I climed in back yesterday but could not work it out
due to a bum leg and bad back so i figured i dig for info
and sucker my buddy into trying to get it out for me tonight.
thanks
Old May 23, 2003 | 12:22 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
1 13mm bolt under each "butt" part. Pull the front up a little, you'll see it.
1 13mm nut in each corner of the seat back.
Old May 23, 2003 | 12:37 PM
ok so what do i need an angled flathead, phillips, or allen key
thanks again
Old May 23, 2003 | 09:13 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
13mm socket and/or wrench
Old May 26, 2003 | 12:00 AM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
w3rd... it was 4 bolts in my camaro(same for my freinds 2001 formula), doesnt do much for you, it weighs in at a wopping 10 lbs - maybe, i never actually weighed it, i do that when i get home
Old May 27, 2003 | 08:08 AM
lol are we talking about the same part.............
i'm trying to get out the back rest of the rear seat
(to install my amps)
i felt an opening for a allen key but just can not find
a way to get leverage
but if worse comes to worse i'll just cut them out somehow!
Old May 27, 2003 | 08:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah; I'm not sure we're talking about the same part. You mean the part of the rear seats of which a person's back would rest against, right? The part that folds forward? Two 13 mm nuts in each lower corner. The seat bottoms have one 13mm nut dead center of the seat bottom, right below a passenger's crotch.... just like Mikes86SC and everyone said. Did someone replace your bolts/nuts with allen headed ones? Odd.
Old May 27, 2003 | 08:33 AM
hey tom how are you doing?
yes the fold down part is what i need to take out....
I pulled back the cloth & foam but only saw a single nut on each side (on the inner portion of the chair near your rear pocket)
so going by feel alone b/c we (there were 3 of us at this point) figured it must be some sort of allen we even looked at several other parts of the car and they were also allen
there is just no way of getting at the nut
Old May 27, 2003 | 10:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You don't need to pull back any cloth or foam... you're not going after the right thing. A 13mm socket on a rachet handle fits perfectly back there. Look again... take out the seat bottoms if you have to.
Old May 27, 2003 | 12:36 PM
that figures
i'll give it another try tonight
thanks again
Old May 27, 2003 | 12:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When you look, remember that you're removing the whole hinge from the car. You dont' unbolt the seat from the hinge... maybe that's what you're trying to do?
Old May 28, 2003 | 02:56 PM
ok thanks again tom
I was able to get them out last night with no problem
Old May 30, 2003 | 09:43 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Also, the entire backside of the rear seat cushions are held in place with industrial strength VELCRO!!!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
