How much does a 2.8 short block weigh?
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
180lbs, w/no water pump. Dumped it at Franklin Iron & Metal. Got $5.85. gas money
. Still have plans for the heads
You found the perfect place for those dead 2.8s
The scrap heap!
I saved my 1985 MPFI heads, too.
Never know, but they're too inferior to the 3.4 heads to do much work on the old 2.8 heads.
The scrap heap!
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
was going to keep my old heads, tell I found a bolt snapped off in one side, and ehaust bolt hole stripped on other side. I junked em.
Kept the crank, cam, pushords, rockers, and guide plates.
