common oil leak spots?
Old May 28, 2003 | 02:04 PM
socialdeviant's Avatar
topic says all.
I had a leak at the valve cover, but replaced that with a rubber gasket, and that was stopped.
I can see a small drip point at the plug.
And before you ask, yes it is tight. I even put a dab of RTV on it every time I do an oil change.
I saw normal seepage at front seal... other then that I need to really steam the engine and see new oil spots...
Ayway, any common drip spots?
Old May 28, 2003 | 02:45 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
distributor oring is common to leak on these engines i think. mine has a little pool of oil at the base of the distributor shaft, u need to take the cap off to really see it. look down there i bet you'll find something similare.
Old May 28, 2003 | 03:46 PM
Nope, sprayed, looked dry.
Found theleak though.. the freggin drain plug, or somewhere therabouts.
who knows how many have owned the car, and the pan has been slammed... might have delveloped a small crack?
Anyway, gonna et back under it tomarrow with a welder just in case.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
