Cold start injector system question.
Old May 29, 2003 | 08:21 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Hi. Does anyone know at what temperature the cold start injector system sensor changes state? Is the sensor a thermistor, or a dry contact type? Thanks!
Old May 29, 2003 | 09:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, you're really into the cold start injector system, eh?
It's neither a thermistor or a "dry contact" sensor- it's not even a sensor. It's a switch. Looked up the temp for you (from the GM Service Manual, http://www.helminc.com , hint hint), any time the coolant temp is below 95 degrees Fahrenheight (39 deg Celsius), the cold start switch is on.
Interesting- the book says that the cold start switch actually heats itself... says the bimetal gets heated by the windings in the switch, and will stay "on" 8 seconds at 20 degrees celsius (didn't give fahrenheit and I don't feel like converting) or below.
I guess that means max time for the CSI "on" is 8 seconds?
Old May 29, 2003 | 10:18 PM
Hell yeah! I've heard of adding a 7th injector to the intake of the GN's, to add more fuel for the higher-boost aftermarket turbos, and I want to experiment with this some more...
The 8-second thing is a bit strange... I can tell when the injector is on/open just by the sound of the engine while accelerating cold. The butt-dyno reports this as well. I'm pretty sure the injector is operating for more than 8 seconds after startup...
It appears to be only a 2-wire device, so the heating thing has me perplexed... Unless it is similar to the flasher module? I'll have to take a closer look at it after it stops raining and I can go out and play.
I'm thinking of a shifter-mounted "fuel performance" button. I should be able to get an aftermarket manual transmission **** with an accessory button. Or, I could just tie it into a TPS monitoring circuit, and open the injector around 85% to 90% throttle...
Does the manual state anything about the injector being PWM, or is it simply open/closed? I don't want to burn the coil out by driving it with 100% duty cycle...
I wonder if it opens at 100% duty cycle at 68°F for 8 seconds and then between that an 95°F it runs at 50% or something similar...
Old May 30, 2003 | 09:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The injector's either on or off, there's no in between.
You know a car gets more power when it runs lean, right?
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
