Fuel Pump
Old Jun 2, 2003 | 10:21 AM
PeNZ's Avatar
Fuel Pump
Ok the fuel pump is supposed to prime, yes. Well today on my J-Body I noticed when I turn my key, I can hear the pump for a sec or two, then I cant but it starts just fine, does it stop making the louder noice when its primed? If it does, my jumper wire power system to the pump on my Firebird never primes, it keeps making the loud noice.
Old Jun 2, 2003 | 10:28 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I do this every time I start my car. First as your turn your key forward it turns on accessories and such, the next click after that, right before the start/crank position is when it primes the pump. I can hear it from inside the car, it lasts about 3-4 seconds. I'm not sure what you are referring to with the "louder" noise. If my system is partially primed (Existing pressure of previous driving) then it will change tones from a higher noise while priming to a lower one. I'm not exactly sure if that will help you, just my 2 cents.
Old Jun 2, 2003 | 10:43 AM
PeNZ's Avatar
yea thats what im talking about, I just have 12v going to the pump from a switch, and it never goes to that lower sound, could this be why its not running good?
Old Jun 2, 2003 | 11:54 AM
Engine: 346ci LS1
Transmission: MN6
I'm not a 100% sure, I'm running the stock pump, it could be different if your pump is aftermarket or something. Is there a reason that you have it wired like that? Do you use it as a kill switch or something?
Old Jun 2, 2003 | 12:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, I'm wondering the same thing. Did you go from fuel injection to carb, and ditched the computer? Never noticed my fuel pump sound, the exhaust is too loud.
Old Jun 2, 2003 | 01:18 PM
PeNZ's Avatar
no fuel pump circut and oil switch circut are fired so I have to power it myself, and just turn your key to acc TomP, and listen to the pump. Dont turn the car on.
Old Jun 2, 2003 | 05:54 PM
Engine: 346ci LS1
Transmission: MN6
Hmmm, I would have to say this is indeed a problem. Becuase I'm pretty sure as soon as my fuel lines are primed, it turns off the pump, and doesn't start the pump till I crank the engine. I think by you running it by switch it just keeps running and running and perhaps you are running the car rich...?
And TomP, PeNZ is correct, the position right before ignition/start is when you hear the pump prime the system. I do it every time I start my car. It gets the fuel to the engine before you go to crank it.
Old Jun 2, 2003 | 06:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
:sillylol: No, no, when I said I never noticed my fuel pump sound, I meant that I never heard any difference in noise between "priming" and "running". Don't forget I've changed my pump twice, and always talk about not "jumping the key" from off to crank! And if your wires are fried, you should really fix them...
Old Jun 2, 2003 | 06:39 PM
PeNZ's Avatar
I dont have the time, im selling my car, well both eventually to get a 96 GTP
Old Jun 3, 2003 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Doesn't take long to trace out all the wires, and might help you sell the car. Visit this link for my code 54 chart; it diagnoses the whole electrical system of the fuel pump. Ignore the fact that you're not getting code 54- 54 is low voltage to the fuel pump, which is why this chart will work for you. Takes maybe 20 minutes, and you just need a test light.
https://www.thirdgen.org/techbb2/sho...63#post1050811
Looks like you guys are going to keep me on my toes... I gotta make sure I word everything "perfectly" from now on! And as part of that, remember this chart is from a service manual for a 2.8. Your relay location may vary... I'm hoping the wire colors are the same.
Old Jun 4, 2003 | 11:19 PM
PeNZ's Avatar
Different colors
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
