Help..code 34 With New Maf!!!!
Old Jun 7, 2003 | 03:54 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
was getting code 34 from my car.... looked at my maf, and there was a tiny wire from the plug to the board inside missing, tried to solder it, and it wouldn't hold for nothing. found a reman. MAF for 50 bucks, figured what the hell, picked it up installed it and NO DIFFERENCE!! still reading code 34 loud and clear, some one HELP !!!!!! (86 2.8 firebird)
Old Jun 7, 2003 | 08:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sounds like you need the code 34 chart to test the wiring, the chart is in this message: https://www.thirdgen.org/techbb2/sho...hreadid=156516
Old Jun 8, 2003 | 12:40 PM
Engine: 2800
thanks..
thanks im gonna have to try all of that today... dont know if i can find a voltmeter tho, but thanks for the info, at least it gives me a direction to take into fixing this problem!!
Old Jun 11, 2003 | 09:00 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
its probly a quick and easy 10 cent fix look over by the battery on the passenger side fenderwel loock for the 2 fuses one is for the maf the other i don't know they should be 10 amp if that isn't it do the wireing check
Old Jun 11, 2003 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You're welcome; you can usually find digital multimeters cheaply; in fact, I think even the neighborhood overpriced Radio Shack has a $10 digital meter now.
There's also the Digital Engine Analyzer, and the Sensor Probe (MAF testing) on discount here: http://www.sunpro.com/cgi-bin/web_st...?page=test.htm
Old Jun 11, 2003 | 11:26 PM
Engine: 2800
the maf not working would cause my car to have poor acceleration, due to the car not knowing the correct air/fuel ratio right?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
