start problem please need HELP!!!!!!
Old Jun 14, 2003 | 09:12 PM
camaro123's Avatar
Hi, I want to start my car this morning, and when I turn the key to the start position nothing hapens, I jump the starter on the solenoid and the car start with no problem,also I jump the swich on the tranny(maybe a bad switch and nothing the car only start if I hot wire the starter.
can be the switch on the steering colum???because is no current to the purple wire on the fuse box BTW the fuses are all OK. How easy is to change the switch in the steering column???.
Thank you in advance for your help
Xavier
Old Jun 14, 2003 | 10:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what type of tranny? soundslike the nuetral safety/backup switch
also, there is always the key cylinder or the actual ignition switch that could crap out too. also check the inline fuse going to the starter. ( I think the cars still have this )
Old Jun 14, 2003 | 11:29 PM
camaro123's Avatar
Hi, the fuse is OK, the tranny is a 700R4, I jump the yelow and purple wires on the safety switch and still the same crap.
Thank you
X
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
