best times
Old Jun 15, 2003 | 09:39 PM
92 RS JD's Avatar
best times
I ran 16.1 today but blew my gasket
Old Jun 15, 2003 | 09:48 PM
unvc92camarors's Avatar
congrats on the 15.1
what all mods do you have?
Old Jun 15, 2003 | 09:55 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
yep, if you're running low 15's mystery mods are definately not an option, now if you say ran 17.1 we'd just give ya the old pat on the back, so, please explain.
Old Jun 15, 2003 | 10:01 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
See sig... haven't run since adjusting the timing, and removing the smog equip.
Yeah, lets see a list of mods, as I'm calling until you do. Short of a 50 shot of the ol' juice, I don't see low 15s.
Old Jun 15, 2003 | 11:11 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Doward, FYI your sig wasn't included there. And I definately thinkin' he was runnin on juice to make those kind of times!! Probably resulting in the blown gasket...?
Old Jun 15, 2003 | 11:39 PM
92 RS JD's Avatar
i have a 3.4
dual k&n setup
custom headers
flowmaster
hyperchip
a/c delete
power pulleys
shift kit
bosch platium plugs
accel wires
These are the major mods
89camaroRSV6's Avatar
no way 15.1...
all my mods and i went 15.9...im maybe a little faster
that that ..(more #lb injectors and some custom prom stuff)
15.1 => "Nitrous" or "Forced induction" or "ur smoking some ****"
Forced induction = impossible...i dont know anyone who has done it on a camaro.
Even nitrous will not shave off 2 seconds by just running a 75 shot
(running higher is definitely a sure way to kill teh engine)
I will have to say this is BS or a serious typo
Old Jun 15, 2003 | 11:41 PM
92 RS JD's Avatar
Also yes i have a 75 shot of juice
Old Jun 15, 2003 | 11:43 PM
92 RS JD's Avatar
sorry i just seen 15.1 -16.1 so sorry for the
Old Jun 15, 2003 | 11:46 PM
92 RS JD's Avatar
It now keeps up with my 97 rs
Old Jun 15, 2003 | 11:57 PM
Engine: 346ci LS1
Transmission: MN6
This is now making more sense as the details are posted.... with the giggle juice and the 3.4 (which I'm not sure if it is a typo or not) I can now somewhat see the time of 16.1 more reasonably...
Old Jun 16, 2003 | 12:00 AM
yes 3.4 with 75 shot with the list of his mods..
i think 16.1 seems ok...
how much hp are you making ???
Old Jun 16, 2003 | 12:06 AM
92 RS JD's Avatar
sorry for the mis type yes i changed it over to a 3.4 225-265
Old Jun 16, 2003 | 12:08 AM
Doward's Avatar
Whoops... here's my sig all... haven't run since the timing and smog removal!
16.1 on a 3.4 + 75 shot? Dang.... what kind of 60'? What mph on that 1/4?
Doward's Avatar
Old Jun 16, 2003 | 12:11 AM
exactly what i wanted to know esp what mph...?
and is it just a 3.4 block on 2.8/3.1 intake or did you swap the entire engine?
SFI/ MPFI??
265 on the wheels?- did you dyno it?
Old Jun 16, 2003 | 07:44 AM
Brian K's Avatar
When I had miine I ran 16.01 all the time.... Then I ran a 15.9 once I did the double roller timming chain.
Mods I had that i can recall:
Ported upper and lower plenum... Major grinding
MSD Coil
Accel Wires
Cold Air with Conical
B&M Shift Kit stage 3
Rebuilt tranny with corvette server
Cragar Rims
235 60 R15 good year tires
Accel 200 Plus ignition
4th gen seats
110MPH cluster
AC Delco Plugs changed each year
New Higher stall with the rebuilt tranny...
Old Jun 16, 2003 | 09:30 AM
devianb's Avatar
I would be more than happy to get a 15.999 so I can say I run 15s. I think 16.1 is still a good time. I probably estimated my 1/4 at 17.2
Old Jun 16, 2003 | 01:55 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
16.48 on my 3.1 auto....only mods worth anything were a Dynomax catback, Catco cat, and 'custom' (ghetto home depot) intake.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
