STOCK Throttle return spring on V6
Old Jun 17, 2003 | 11:34 AM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
I have a stock 1984 2.8L V6 firebird. I have been having idle issues with it since I have bought the car. Pontiac doesnt know a thing about what throttle return spring belongs on the stock carb. The two shops I went to put on quite tight springs. I need to know, how tight should the springs be? Or if anyone has pics of their V6 throttle return springs, so I can see how streched they should be at rest, PLEASE post them!
I dont like feeling like I am pressing down on an unopened bottle of soda....Unless that is how stiff it should be...which case maybe it's time to look into EFI.
Thanks!
PS Yes I posted this as well in the Carb forum, howerver with this being a V6, I usually don't have much luck with that forum.
Old Jun 17, 2003 | 01:20 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
The throttle return spring should not be super tight. At rest it should be a little stretched out. Check in the Help section of AutoZone for a replacement if yours is too tight. They have some stock replacements there.
Old Jun 17, 2003 | 06:10 PM
Jurrel's Avatar
Car: 1984 Firebird
Thanks Ill check autozone then. All Kragen's has are generic throttle retun springs and pontic had one spring listed for all engines ever used in the firebird....
Old Jun 17, 2003 | 09:49 PM
The spring off of my 82 t/as 305 was the same as the spring off my friends 84 2.8 .. both carbed. Both not too snug and not too loose
Old Jun 17, 2003 | 11:39 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Whenever mine broke I replaced it with a return spring from Summit. (I wanted a red one). It is stiffer than the stock spring but not by that much.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
italiano67
Dec 11, 2016 09:21 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
