Squeaky engine
Old Jun 19, 2003 | 07:48 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Squeaky engine
My engine has this very noticeable squeak. I don't think it's a belt. It sounds like it's coming from the front of the crank. Any ideas? If you stand at the side of the car, this squeak competes with the exhaust for loudness. It's going at the frequency of the engine.
Old Jun 19, 2003 | 08:07 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
From what I have heard recently, could be your water pump bearings.
Old Jun 19, 2003 | 09:37 PM
Thanks for the idea.
What have you heard lately?
Old Jun 19, 2003 | 09:46 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You sure it's not your belt or tensioner squeaking? Pull the belt, start it for just a second, and see if it squeaks (please, don't run your engine for 10 minutes, and it overheat, and blame me. )
Old Jun 19, 2003 | 10:51 PM
Ah Doward, I can always count on your reply for a good laugh. Which belt would you like me to pull? And don't worry I won't run it for 10 minutes.
Old Jun 20, 2003 | 06:40 PM
Jurrel's Avatar
Car: 1984 Firebird
Just on a few posts someone mentioned a squeak that was not a knocking sound from the engine. I 'think' it was Tomp, but dont hold me to that, who suggested that it might be the water pump. Those are cheap and relitively easy to change, least it was on mine...So Id replace it if you haven't found any other reason for the squeak....better then the water pump seizing up on you and over heating the car sometime.
Old Jun 21, 2003 | 12:33 AM
Doward's Avatar
They weren't serpentine in '86?
Sorry, I don't know the exact dates on the switchovers
If it's a V Belt, then remove each belt, one at a time, and see if the squeaking stops. If you remove a belt, and it stops, you've found the problem.
If you remove all the belts, and the squeaking continues, then at least you know you've eliminated one of the 'possible' causes.
Old Jun 21, 2003 | 02:09 AM
Sounds logical.
What do you mean by serpentine, and switchovers?
Old Jun 23, 2003 | 12:48 PM
Jurrel's Avatar
Car: 1984 Firebird
Serpintine means one belt was used to replace the 3 conventional V belts.
Switchover is used to mean the year that it switched over from the 3 conventional V belts to the serpintine.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
