Anyone fuel gauge do this?...
Old Jun 23, 2003 | 05:01 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
As I was driving home, my fuel fauge started going up and down.It then setteled as I was on the highway.I also noticed it would go up as I accelerated and went down as I slowed.I don't mean the level of the fuel in the tank was causing this as I sped up or slowed down to stop.Just as I gave it gas or let up off the pedal.The fuel filter has been replaced.It seems to idle fine.It had water in the tank at the time of the filter change and I put in alcohol to relieve that problem.I'm thinking the pump might be going out.The car seems like it does'nt have the get up and go like it used to.The engine has around 60k on it.But the fuel pump is still original.ANY SUGGESTIONS?????
Ken
Old Jun 23, 2003 | 05:30 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
althogh i have only owned a thirdgen for two majical weeks (applause), i would think it is probably the wires to your fuel guage. ir mechanical guage workings inside tank. the fuel pump shuld not cause the fuel guage to do that.
but thats just my two cents, maybe someone with an actual knowledge of fuel seystems will back me up here?
Old Jun 23, 2003 | 07:53 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Mine will read empty under hard corners with Half a tank of gas- Under 3/8 a tank I will cavitate the fuel tank and the motor will bobble in the turns under hard g's- Normal street deriving it won't bobble around a normal speed corner unless I am under an 1/8 tank. Most older car fuel gauges move like you discribe, thats normal- its caused by poor or no baffling in the fuel cell.
Old Jun 23, 2003 | 08:10 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
my fuel gauges fluates(sp)...i went & tried to get a new floater for it & it costs like $500.00 thats i just kinda guess how much fuel i have-lol.....~cristy
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
