What is this part sticking out?
Old Jun 27, 2003 | 04:59 PM
stiers's Avatar
Well, I just bought a '86 V6 Firebird yesterday, check out the thread in A&D.
https://www.thirdgen.org/techbb2/showthread.php?s=&postid=1373875#post1373875
Anyway, I was about ready to see if it runs until I saw this thing sticking out with nothing atatched and was wondering what it was?
Also is there supposed to be a fastener holding the MAF to the hose leading to the aircleaner? There is one holding the hose to the aircleaner, but the MAF has notches but nothing to hold it in?
I am sure I will have more questions later, esp. if it still doenst start but this is it for now.
Old Jun 27, 2003 | 08:51 PM
stiers's Avatar
seriously guys, one of you should know this, or can you at least go look at your car and see if it looks the same.
Old Jun 27, 2003 | 08:59 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
mine does not look the same
but i have an 89.
Old Jun 27, 2003 | 09:27 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I've got one too...I believe it has something to do with the timing, but thats as much as I can tell you...sounds like a good one for Tom...
Old Jun 27, 2003 | 10:13 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Can't really tell from the pic, but that's the location for the timing tabs. That's used to determine engine timing when you have a light. I think you should have another hose clamp on the hose for the MAF, don't want any air leaking in.
Old Jun 28, 2003 | 10:22 AM
icebird_1981's Avatar
hey i think i have one of those on my bird and some line runs to it i will check for ya in a bit.
Old Jun 28, 2003 | 05:18 PM
BitchinRS's Avatar
Some engines have these, but no the other part. It's so you can put a magnetic pick up in there to pin point your timing. So far I have never seen an engine magnet on the balencer so it can be used.
It would be kinda neat to be able to use. then you will be able to tell that you are absolutly at 10 BTDC, but going by the mark is just as good.
Old Jun 28, 2003 | 06:02 PM
stiers's Avatar
So can I just leave it as is and not worry about it or does it need a cover or something?
Old Jun 28, 2003 | 06:47 PM
BitchinRS's Avatar
You can just leave it. there is no cover for it.
Old Jun 28, 2003 | 08:35 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
that is for a mag timing probe, you use it when you have your car on a scope. The balancer has no magnet, the probe is magnetic, it can just read the mark on there because the magnet is so close to the balancer, all you have to do is program an offset in the scope. works really good at pinpointing spark scatter, I use one all the time at work.
LT1Formula
20
Nov 14, 2015 12:02 AM
Bert87
Aug 23, 2015 03:50 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
