Wonder bra err... BAR
Old Jun 28, 2003 | 05:41 PM
BitchinRS's Avatar
I'm happy as a pig in... well... "stuff". My wonder bar came in, but I am not completly sure ware it bolts up to. If any one has pictures showing ware it bolts to it would be a great help.
Thanks!!!
Old Jun 28, 2003 | 06:42 PM
Xceleratemaro's Avatar
it bolt to the sway bar bushings!
i have one on my car but i dont have any pics right now..just place it twared the front of the car and lay it over the bushing and yoall see what im talking about.
Old Jun 28, 2003 | 07:43 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Grr, wish I would have read this earlier, and snapped a better pic. the one I intend to attach was taken for a fan mod. But you can "somewhat" see the brace.
It attaches between the "frame" and swaybar mounts. wonderbar bar infront of the swaybar.
I advise using a small jack for your assistant to help hold the swaybar while bolting things back up.
Old Jun 28, 2003 | 11:27 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Badabing! I had to move the lower radiator hose back towards then engine a bit with a little modification. The bar runs right where the hose previously was. Nothing big!
If you want more pictures let me know!
Old Jun 29, 2003 | 04:22 PM
BitchinRS's Avatar
AHHH that's perfect!!!! Now I know what I am doing! All though some would I never know what I am doing. Is the sway bar that hard to put back in postion that you need to use a jack. If it is it is no big deal I have an extra jack.
The hell with it, I'm going to go out right now and see if I can get it on.
Thank you very much!!!
Old Jun 29, 2003 | 06:34 PM
BitchinRS's Avatar
Took me about 20min. Turn out I didn't need to use the jack. Working on laptops I had to learn how to start a screw with one hand while holding parts with the other.
The stearing feels a bit tighter. I imagine it will be even tighter when I get a STB.
My only warning to any one who is going to this job. KEEP YOUR HEAD OUT OF THE WAY OF THE SWAY BAR!!! OCCCHHH! I never removed the sway bar bushings before and didn't know it would swing down. Oppss.
Old Jun 29, 2003 | 06:50 PM
Dale's Avatar
Engine: 350 S-TPI
Thats why I said to use a jack, LOL. That and to help hold it while starting the bolts back in.
Old Jun 30, 2003 | 12:05 AM
Engine: 346ci LS1
Transmission: MN6
It was quite easy to take the two sway bar mounts off to put the wonderbar under it. I didn't use jacks. I have a car pit under my car, as you can partly see in the one picture, I can simply stand under my car to work on it! It was quite an easy install.
If you have any other questions let me know.
Old Jun 30, 2003 | 10:57 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL; I probably would've just bunjee corded' it to the hood latch
Old Jun 30, 2003 | 11:21 AM
Dale's Avatar
Engine: 350 S-TPI
That would work too tom, LOL.
I just remember after I got done cussing it, and bolting up. That would have been easier using a jack, rather then me curled up in fetus position under car holding it with my legs. LOL
Old Jul 7, 2003 | 05:28 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
uhhm... :::prepars to be publicly mocked:::: what does a wonderbar do?
Old Jul 7, 2003 | 08:48 AM
Dale's Avatar
Engine: 350 S-TPI
Supports/braces the front so that it wont twist/flex in hard cornoring.
Helps with small bars, and is almost a must with larger bars.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
