V6 Fuel Economy = Poo
Old Jun 29, 2003 | 03:55 PM
Purple Monkey's Avatar
Car: 1990 Eagle Talon TSi AWD
Engine: 4G63T
Transmission: 5 speed
I'm just wondering what everyone else with a FI 2.8/auto gets for milage, I get about 14-17 consistantly, and that sucks. My 84 z28 with a 350 and 4.11s will get 19 all day long.
to correct the problem (and for fun) I have done:
full tuneup including new wires
repaied exhaust leaks
home made cai
cat delete
AFPR - 46psi
timing 12 deg
patched up any vacuum leaks
replaced maf
I also get intermittent codes
34 - maf circuit voltage low
44 - exhaust system lean
weird how I'm pretty sure I am severely richening below 3K RPM
I had a scanner on it and it was showing like 65 points rich at idle.
And it likes to try to stall at lights, but it's a weird stall. Makes a funny noise and seems like it just dumps gas in for a second and almost stalls then throws a code 34.
it's pretty and I just want it to run good!
any ideas would be great, thanks.
Old Jun 29, 2003 | 03:57 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sounds to me like a new MAF and O2 sensor are in order....
Also, turn your AFPR down to about 42psi...
Old Jun 29, 2003 | 03:58 PM
Doward's Avatar
Just noticed you replaced the MAF... was it one for a V8 or V6? They were different, if I recall correctly...
Old Jun 29, 2003 | 04:18 PM
Engine: 4G63T
Forgot to mention, have a recent o2 sensor as well
and 42psi is stock
yes, replaced the maf with a brand new GM replacement.
yes the v6 and v8 mafs are different:
v6 maf = 3 wire hot film style made by ac delco
v8 maf = 5 wire hot wire style made by bosch
Old Jun 29, 2003 | 04:26 PM
Doward's Avatar
Very odd... with everything having been replaced, I'd recommend running a data scan while the engine is running, and work from there.
Have you checked to be sure you have 12v at the MAF?
Old Jun 29, 2003 | 04:27 PM
Doward's Avatar
Oh yeah, I know 42 is about stock... I'd recommend keeping it stock until you get the engine running smoothly, then change the fp and such...
Old Jun 29, 2003 | 04:41 PM
Engine: 4G63T
I think i'm going to try running down the flowchart on those codes again.
I wish my car was OBD II
freeze frame is awesome
I'm pretty sure it'sa fuel trim problem
put the computer in backup spark and fuel and it runs great...
I hate problems that can't be solved with a wrench
Old Jun 29, 2003 | 05:07 PM
Doward's Avatar
LOL, I know what you mean... but if you want to work on 'em, you just gotta grit your teeth, and figure it out.
Imagine in a couple years, they might be going 'Man, I hate problems I can fix using electronics' What will they be then?
Old Jun 29, 2003 | 09:53 PM
Engine: 4G63T
I had a thought, how about a really slacked timing chain. It seems to randomly lose vacuum so maybe it's just bangin around the cam at idle? then I take off and it acts better...
sound possible?
I checked the maf and all the wiring and it seems fine.
I can't see the computer just randomly doin all of this...
I'm desperate to figure this out... if you can't tell.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
