Fired her up after the 3 weeks of wrench work and here are the results...
Old Jul 1, 2003 | 11:54 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Well, let me start by listing my problems I had before the work was done....
1. Oil leak on the transmission (rear main seal went bad)
2. Clutch engaged extremely high on the pedal.
3. Had a bunch of electrical tape splices from the previous owner on the wiring harness...
4. 1500 rpm idle.
Ok heres the list I did. I took my time with all of it to make sure it was done right.
1. Replaced rear main seal (after much trouble with the transmission).
2. Put a new flywheel in (old one was warped).
3. New clutch, pressure plate, and throwout bearing.
4. Installed a new wiring harness.
5. Replaced the oil in the transmission.
Ok now the clutch engages just where I like it. I fixed the oil leak. Everything went great but I was kinda hoping the new harness would magically fix the idle problem. I can't figure it out, it just stays at 1500 and just slowly goes down to 1300 when the engine runs warm. I replaced the IAC and TPS, I just can't figure this one out. Im not sure how to test the coolant sensor. Yes I reset the IAC by the paperclip method, did it correctly a million times and it didn't work. I have no vacuum leaks, I had the shop do that. I am just out of ideas, someone please help me with this stupid high idle issue.
Old Jul 1, 2003 | 11:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
is it timed correctly?
Old Jul 1, 2003 | 11:59 PM
pasky's Avatar
Can't fix the timing ti'll I lower the RPMS....Otherwise when it gets lowered gotta time it again. Its not way off currently, I belive its at 8 BTC, i could be wrong, havn't checked in a while.
Old Jul 2, 2003 | 12:07 AM
Ovrclck350's Avatar
Adjust the minimum idle speed. I believe it's the same way as on a TPI car, I just can't remember the procedure.
Old Jul 2, 2003 | 12:08 AM
pasky's Avatar
Did that, its the screw in the back of the throttle body, I already did the procedure and shorted the diagnostic terminal, let it sit for 50 sec ti'll the IAC is shut and adjusted min idle to 550 rpms with IAC unplugged, plugged her back up and what do ya know....idles at the same damn area. I tried adjusting with IAC plugged in and I had the screw all the way back and didn't drop a bit.
Old Jul 2, 2003 | 03:31 AM
pasky's Avatar
Idea's anyone? Just throw them at me and i'll state whether its been tried...Im just so fed up, the car runs great except for this problem and its also upping my mpg =/
Old Jul 2, 2003 | 05:35 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
im in kinda the same boat w/ the idle problem. mine fluctuates a bit more than yours does though.
Old Jul 2, 2003 | 07:25 AM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
Actually, or at least on my L98, I could pretty much set my idle by adjusting my distributer, I just hook up a timing light that has a tach and turn distributer till the rpm gets where I want it. if you cant do that then ok it may only work for me.
Old Jul 2, 2003 | 07:54 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Its probably that coolant sensor. I dont have a book handy but what its a $8 part.
Old Jul 2, 2003 | 03:01 PM
pasky's Avatar
Why would the coolant sensor cause this? Not doubting you, just curious before I shell out more $$$
Old Jul 2, 2003 | 03:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What year/engine is the car, again?
Old Jul 2, 2003 | 04:16 PM
pasky's Avatar
1991 RS, 3.1 /w a T5
Old Jul 2, 2003 | 05:02 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Back the dile screw all the way out. if you shut the Throttle blade by hand does the idle go down to about 800? if this is the case, your Throttle return spring is weak. Go down to pepboys and buy a $3 carb throttle return spring. I did this on my car, worked perfectly. you can see a pic of it on my cardomain site.
Old Jul 3, 2003 | 02:26 AM
Really-Slow-RS's Avatar
This is kind of like a cold start device I believe, it acts like a choke and lets more fuel into the combustion chambers causing a high idle. If I'm wrong someone let me know, because if I'm wrong I would also like to know the correct answer.
Old Jul 3, 2003 | 02:28 AM
It's off topic, but where in Tx do you live? Just saw that below your user name.
Old Jul 3, 2003 | 03:53 AM
pasky's Avatar
Laredo...
1992rs/ss
Jan 31, 2025 05:10 PM
92camaroJoe
Jul 29, 2023 07:57 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
