Need info onsprings/shocks from a 4th gen!
Old Jul 6, 2003 | 12:38 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What is the spring rate/length of the '93-'02 V8 Fbody springs vs our V6 springs?
Will '93-02 V8 Fbody shocks/struts work on a '82-'92?
Old Jul 6, 2003 | 08:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
No, the front 4th gen struts are a totally different design.
However, I belive the rear shocks are the same, it was dicussed several months ago by ked85
Old Jul 6, 2003 | 11:20 PM
Doward's Avatar
How about the spring rate? I'm wondering if I can snag some takeoff V8 springs, slice 1/2 a coil, and be a happy camper... but I need to know the spring rates!
Old Jul 6, 2003 | 11:46 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Rear shocks are the same. Don 't know about the spring rates.
What are you looking for: Lowered ride, stiffer front end,...? I cut my spring to match the broken other side. for "lowered" spring, jsut buy the ones for a V6, manual w/o a/c.
Old Jul 7, 2003 | 12:05 AM
Doward's Avatar
See, that's almost what I have now... manual v6 WITH a/c...
I may end up going Dropzones, since I can score those on Ebay for around $100. I think first should be some LCA's tho...
Old Jul 7, 2003 | 08:51 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, 4th gens use an upper control arm, with a shock; and the spring is on the shock. The suspension/chassis/brakes forum would probably have more info on spring rates... or check out the v6 area (mostly 4th gens) at http://www.camaroz28.com
Old Jul 7, 2003 | 11:56 AM
Doward's Avatar
Fronts won't work anyway... they went to coil-over shocks. Dang... ok, DZ's it is!
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
