Dual Snorkel intake (tpi)
When doing the Dual Snorkel intake swap, I'm going to have to extend the wires on my iat sensor, right? What kind of wire should I use to do this, just pickup some primary wire somewhere and solder it? I'm sorry if this is a stupid question. Does it matter what gauge wire I use?
Mathius
Mathius
Car: 1986 Firebird
Engine: 2.8 V6
Probably want to use 18 gauge; try to match what the current sensor's using. Definately twist & solder those; see if you can find heat shrink tubing (radio shack) and use that instead of electrical tape. We're not talking about miles of extra wire here so the resistance induced by extending the sensor's wires would be extremely minimal...
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes, I had to extend mine. I used *gasp* speaker wire. It was same size wire as in harness, brand new, and were side by side.
I did solder them together, then elec tape around them. I don't have heat shrink tube. It would be better.
Car: check
Engine: check
Transmission: check
RBob.
Engine: 350 S-TPI
Originally posted by RBob
All well and good, but the real question is, how does it sound?
RBob.
RBob.
Sounds really good
, kinda like a small v8, LOL. Moderator
Car: check
Engine: check
Transmission: check
Sounds really good
Sounds really good
, kinda like a small v8, LOL. Then as I vacuum bled them I was almost done and forgot to keep an eye on how full the jar was getting. Yep, dang MityVac really sucks up and sprays the fluid out with that 'last' pump.
The good part is that I'll be able to drive her without a sudden lane change every time the brakes are used.
RBob.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
