Another Question from the little guy... 2.8 compatible with 3.1?
Old Jul 9, 2003 | 07:40 PM
Firebirdjoe's Avatar
Car: 1987 Pontiac Firebird 82k miles
Engine: 2.8 V-6 (173 c.i.)
Hey guys, I have another small question...
I dropped a 2.8 V-6 from a 1988 Firebird into my 1991 3.1 V-6. With everything hooked up, are the computer parts compatable? We had a problem with the EGR valve wireing harness' coming together. I'm trying to explain this the best I can, I'm not too bright when it comes to cars...
Thanks, Firebirdjoe
Old Jul 9, 2003 | 08:08 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
as long as you use the accessories, harness, ECM, etc. from the '91 you should be fine. Good luck with it.
Old Jul 9, 2003 | 10:02 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Shouldnt it be the other way around man?
Old Jul 9, 2003 | 10:21 PM
socialdeviant's Avatar
with the EGR, reuse the one from the 3.1.
More then likely the 2.8 one is a vacuum oriented one, not electronic.
If you have any doubts about compatibility, remove the sensors from the 3.1 and install them on the 2.8.
Old Jul 9, 2003 | 10:32 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
for the right price, I might be able to come down & help out
Old Jul 9, 2003 | 10:59 PM
Thanks for the help guys, I'm going to do some more research and see what I can dig up. This car is having a ton of problems.
Old Jul 10, 2003 | 06:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Which ECM & wiring harness did you use, the one from the 2.8l or the original one from the 3.1l?
The reason I ask is that they are completely different and will be the deciding factor on a number of things. IE: The 3.1l in the '91 uses a MAP sensor, whereas the 2.8l from the '88 uses MAF.
RBob.
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
wild1
Aug 27, 2015 09:01 AM
redmaroz
Aug 16, 2015 11:40 PM
the_nikfive
Aug 11, 2015 02:46 AM
