Starter problems
Old Jul 14, 2003 | 03:04 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Starter problems
Ok folks, last post for the night unless someone replies, which I doubt. Ok, I removed my transmission and bellhousing the other week and everything went smoothly. I now I have the dustguard on correctly for the bell housing but for some reason my starter does not fit in as snug as it used to.
Now when I start the car I get a nasty grind noise. It is either it is too far away from the flywheel or too close and was wondering if maybe I missed something. It bolts up fine, but I really have to shove it in before I can get the bolts straight and it was never like this. Maybe you guys can give me a hand on what to check cus it is really bugging the **** out of me. Thanks.
BTW, it never had to use the shim before so I don't think spacing it is the problem, I can't see anything obstructing it at all, but maybe you guys know something I don't, thanks.
Old Jul 14, 2003 | 03:50 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
uhhhmmmmm..... that grinding noise is the teeth on your starter gear wrestling with the teeth on your flywheel, guess witch one will break first, i say flywheel will strip first, that starter has one hell of a doubleleg (wrestling move)
::rundown in english::.. stop starting your car till you fix this. just park on hills and bump it. you are going to break somthing.
BTW i apologize for the first paragraph, i am tired and it is 2:17 am. i am leaving it cause it is just too funny
Old Jul 14, 2003 | 04:38 AM
pasky's Avatar
Ok, anyone else with ideas....BTW I already knew its touching the flywheel, liek I said, its either too close or too far . Just need to know if maybe I missed something possibly while putting the bellhousing dustgaurd (flywheel inspection plate I hear it being called here) on. In fact, it would be great if someone with a manual 88-92 V6 could just snap a picture of the starter going into the bellhousing and get a good enough picture to where I can see the dustgaurd and i'll go from there, thanks.
Old Jul 14, 2003 | 08:25 PM
pasky's Avatar
up you go.
Old Jul 15, 2003 | 12:14 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
maybe when you took the starter off either:
1) shim(s) stuck to the motor & fell off afterwards
2) a shim agrevatingly flew off in the removal of said starter (been there, seen that)
3) shiz happens
Old Jul 15, 2003 | 01:40 AM
pasky's Avatar
Hehe, suppose I could try using the shim.
Old Jul 15, 2003 | 12:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, definately use the shim.
It's been a while since I looked it up, but I believe for proper clearance, you need a depth of a paperclip's wire's thickness for proper operation. As in, when the starter gear engages the ring gear, you can slide a paperclip between the "extreme ends" of the meshing teeth.
Old Jul 15, 2003 | 04:04 PM
pasky's Avatar
Would just like to take this time for everyone to know that yes, they need shims, works great now. Suppose you were correct, I bet the shim got stuck on when I took the original off and just fell off somewhere. THanks folks.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
