alternator question
Old Jul 15, 2003 | 07:08 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
alternator question
my camaros an 85, what other years did they use the same alt. set up??
Old Jul 15, 2003 | 11:36 PM
F585's Avatar
Take off the pulley and then you can say fits 82-92 Camaro/Firebird.
Old Jul 16, 2003 | 09:13 AM
KED85's Avatar
Not TOTALLY correct!
The 1985 & above alternator KICKS out lots of juice due to engine electronic demand.
The alternator usage for a 1982-84 is way lower in juice output.
You can fry your electrical system if ya use an alternator putting out to much juice.
My 1985 altern. kicked out a high voltage spike that was killing my ECMs. I went thru six ECMs before I discovered the alternator was bad. Car would be driving then all sudden it died.
Old Jul 16, 2003 | 09:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep! My old parts car (84 2.8) had an alternator rated for 67 amps- with air conditioning. 85-86 (not sure 87-92) is something like 105 amps. And some more info; the alternator is only used from 85-86. 87-92 uses a smaller case that fits into the serpentine belt tensioner bracket.
Cornholio7979
Sep 20, 2018 02:31 AM
dutch930
Sep 11, 2015 06:58 AM
Cleotiz
Aug 23, 2015 12:07 PM
redmaroz
Aug 16, 2015 11:40 PM
