how to remove rotor, no screws like Haynes says
Old Jul 20, 2003 | 03:28 PM
kakarotto's Avatar
Car: '91 camaro RS
Engine: 3.1L V6
Transmission: t-5
How do you remove the rotors on our cars (3.1L '91 camaro RS)? There aren't any screws on the rotor as the Haynes manual shows.
Old Jul 20, 2003 | 03:50 PM
Ovrclck350's Avatar
cap has 2 screw, rotor just pops on and off.
Old Jul 20, 2003 | 03:58 PM
kakarotto's Avatar
Car: '91 camaro RS
Engine: 3.1L V6
Transmission: t-5
mine wont come off, I've applied a lot of force to it and still nothing.
Old Jul 20, 2003 | 04:03 PM
90RSRocks's Avatar
Car: White 1990 Camaro RS
Engine: LH0 V6
I just replaced mine, had to tap it really hard to pop it off, it was a PITA. Getting the new one on was fairly easy though, just make sure it lines up right. Good luck.
Old Jul 20, 2003 | 04:28 PM
kakarotto's Avatar
Car: '91 camaro RS
Engine: 3.1L V6
Transmission: t-5
Took a wrench to the back of it and hit it a few times, came right off. Thanks for the advice
I was a little scared of breaking it seeing how it is made out of plastic and all.
Old Jul 20, 2003 | 04:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
When I bought mine, the car had sat a year, and was not maintained. I ended up using a dent-puller with a "L" on the end to get it off.
Old Jul 20, 2003 | 06:46 PM
devianb's Avatar
Mine was a little stubborn too, but it came off without any problems after a little coaxing
Old Jul 20, 2003 | 07:35 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Man I just pulled that bitch off! Don't be too scared! Just watch it when the thing comes off, because the last time I did it, I broke the vacuum line right above it! You are talking about the rotor in the distributor right? Not the brake rotors?
Old Jul 20, 2003 | 08:19 PM
kakarotto's Avatar
Car: '91 camaro RS
Engine: 3.1L V6
Transmission: t-5
Yeah I was talking about the distribuor rotor. Also when I went to connect my new plug wires to my new plugs (rapid fires) they were very tight so I stopped pushing on them. I believe the size of my wires are 7mm, are these too small for the rapid fires? I have read many posts of people buying 8mm wires, but the guy at Napa told me these would work. Am I being too gentle with the plugs?
Please excuse my ignorance as my car knowledge is very limited, but I am learning.
Old Jul 20, 2003 | 08:41 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
7mm will be fine. For your application. Other cars, 8mm might be a good idea....but these cars, you won't see any difference from the extra millimeter.
As far as the plugwires....did you hear an engagement click noise when you pushed them on? Sometimes they feel like they're on the tightest they can go til you push em harder. You can push the living sh*t out of them all day without problems AS LONG AS YOU PUSH DIRECTLY ON THE END! As in, directly over of the plug. Don't push on the rest of the boot. Don't twist it or bend it. Just push straight down..otherwise you can damage the boot or the connections inside it.
Old Jul 20, 2003 | 08:55 PM
kakarotto's Avatar
Car: '91 camaro RS
Engine: 3.1L V6
Transmission: t-5
Thanks a lot Nixon1, I will finish attaching everything tomorrow. I can't wait to get it back up and running to see if it will fix the cold start problem I am having.
Old Jul 22, 2003 | 08:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: how to remove rotor, no screws like Haynes says
The Haynes is probalby not showing you -your- distributor cap. http://www.helminc.com and follow the "Do It Yourself" link.
Frozer!!!
Jan 19, 2024 04:55 PM
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Wife'sCar
Aug 22, 2015 01:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
