i though it would fit
Old Jul 31, 2003 | 11:25 PM
icebird_1981's Avatar
k my wiper motor is broke on my 83 z28 so i took it out and took the one out my 84 v6 firebird, hook it all up and go to plug in the wires. (it dont have the same fitting!) i figured it would all be the same and never bothered to check. the one off the bird is like a box shape 3 wires and the one on the z is a line one also 3 wires. is there anyway i could get this to work? could i just cut the box plug and connect the wires? is it all the same??
oh also the one form the Z has like a L shape plug in the motor and the bird dont. what the L one for?
both motors are delay.
Old Aug 1, 2003 | 01:52 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Assuming everything else is the same, you could steal the plug out of your f-bird also. Or you might be able to find a new plug from the dealer or a reproduction parts place. Then just solder-splice the new plug on using heat-shrink, or just install the new plug properly (which might be the hard way).
If you can find wiring diagrams for both cars, then you can figure out if the motors are compatible.
Old Aug 1, 2003 | 02:33 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
DO NOT BUY A NEW PLUG, you still have the broken motor right, cut the plug off the firebird moter, toss it, cut the plug off the camero motor, match the collors and connect working motor to fitting plug, if collors dont match then experiment. you cant realy do mutch besides blow a fuse. good luck
Old Aug 1, 2003 | 05:47 PM
kool thanks saves me a trip to the yard
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
