3.4 Cam
Old Aug 24, 2003 | 03:11 PM
godsapprentice's Avatar
3.4 Cam
I have an '87 that was originally equipped with a 2.8. I swapped in a 3.4 out of a '95 Camaro. Now it seems the engine has a blown head gasket, so when I tear it down, I want to replace the cam while I'm there. But everwhere I've looked, it seems the '95+up 3.4's use a roller cam. I haven't had any luck finding anyone who makes an aftermarket cam for this motor. Does anyone have any suggestions as to where to look? Do you know if I could go back to a normal Hydraulic Lifter cam?
Thanks.
Old Aug 24, 2003 | 04:32 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
You must be looking @ the fwd engines. No 3.4 rwd engine came w/roller anything stock. ou have a regular hydraulic valvertain in it.
Old Aug 24, 2003 | 08:52 PM
KED85's Avatar
Totally correct.
I got two 3.4s & they both have simple Hyd. Cams.
When ya do your job, take off both heads & have them planed for removing any warpage.
IF ya got the bucks, also install new valve seals to cure future soon to happen oil leak into cylinders.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
