Help on valve cover gasket replacement
Old Aug 24, 2003 | 07:15 PM
kmyers242003's Avatar
i have a 1991 camaro RS with a 3100 V-6. I went to auto zone and bought some new valve cover gaskets, but, the problem is i don't know how to take the injector stuff off of the engine to get down to the valve covers. i don't know to much about taking injectors apart so any help will be appreciated.
Old Aug 24, 2003 | 08:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Take the upper part of intake off.
Take long screw driver, and gently pry on the fuel rail, it should pop out.
remove lower intake
Then you should have access to valve covers.
Also, a haynes or chiltons manual should have better step by step.
Old Aug 24, 2003 | 08:35 PM
KED85's Avatar
On the thin sheet metal valve covers make sure the edge is good straight, not bent or wavy.
Take a hammer (tap lightly!) to the metal cover sealing edge to correct any previous damage, to get best gasket seal.
Old Aug 27, 2003 | 06:35 AM
3.1LFirebird's Avatar
just did all that last night for a lifter
you gotta remove the intake and fuel rail
and you will probobly need to move your coil, and a pipe that runs into the egr
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
