MPFI Block 2bbl Manifold
Old Sep 5, 2003 | 07:59 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
What intake gasket do I need to put an '84 2bbl Manifold onto an '86 MPFI Long Block?
Do I need the FI gasket or the 2bbl gasket or are they the same. parts stores can't seem to tell me. Thanks
Old Sep 5, 2003 | 09:37 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
Either one will work. I put the 2bbl intake on a 88 bird 2.8. I used the 88 intake gasket.
The only difference is that the old gasket has a metal plate with a hole inside it in one of the port. The fuel injected gasket did not have this. I used the fuel injected one because i figured it would flow better without the metal plate.
To make it short it runs great using the 88 gasket.
Old Sep 5, 2003 | 09:39 PM
Cool. I have the 2bbl one and it has a metal plate also. It's a water cross over. I can take it out. Thanks!
-Paul
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Rally Smith
Sep 14, 2015 06:59 PM
Kenwood
Sep 11, 2015 12:50 PM
