v6 alt? same?????
Old Sep 16, 2003 | 10:21 PM
icebird_1981's Avatar
v6 alt? same?????
i put my v6 altinator in my v8 camaro because it went, i changed the pully because the v6 had AC and the camaro does not. anyway i am useing the same batter that was in the bird and same altinator, when they were in the bird the bat gauge use be be almost up at the top. since i put them in my v8 the gauge says it just below half. i no both gauges work fine, what i am wondering is is there a diffrence in power for the v8?? do i need a diffrent altinator? is it ok to use the v6 one in my v8??
Old Sep 16, 2003 | 10:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
how many amps difference between the two alts?
Old Sep 25, 2003 | 09:38 AM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
Yes...no i cant say forsure..but when you go to autozone to buy an alt..they ask what engine...so they ahve to be diff right?
Old Oct 1, 2003 | 09:51 PM
KED85's Avatar
V6 MPFI WITH AC & power options takes the 105 AMP.
NOTHING LESS.
No matter if V8 or V6 I'll bet.
All FI drivetrains probably take the 105 amp unit.
Old Oct 1, 2003 | 11:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It also depends on the year. I think later model fuel injected motors had a few different amperages. My parts car '84 2.8 V6 firebird, with air conditioning, had a 74 amp alternator. What years are the cars?
Old Oct 2, 2003 | 10:03 AM
the alt is from a 1984 v6 firebird with ac. i got it on a 83 v8
Old Oct 2, 2003 | 10:49 AM
KED85's Avatar
That is the same item as for my 1985 S10 Blazer w/AC.
You have the correct item. Housing may have to be rotated for fitment in the V6 engine bay.
BDR
Nov 7, 2015 03:05 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Slush92RS
Sep 2, 2015 08:56 PM
firestorm
Oct 2, 2000 09:57 AM
Mkos1980
Sep 20, 2000 10:00 PM
