Yes, Finally!
Old Sep 30, 2003 | 11:15 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yes, Finally!
Its a 91 RS 5spd 3.1
My white dragon is up and running (haha get a kick out of that movie when he says he is giving the red dragon a little more power) for the love of ***. I actually can drive it around again! I do have two problems now still, she idles fine when I start her up but if I gain some speed and begin to slow down the rpms drop slowly and sometimes stay at 500-600 and pick back up or it dies sometimes. I'd say its more than a 50 percent chance she dies but sometimes she won't. ANy suggestions?
Already checked most vacuum areas, but havn't checked thouroughly yet because its pretty late. I checked the IAC, that seems to be fine. Can someone pinpoint the major areas of it causing to stall while slowing down only? Also, gauge lights and shift indicator are not working all gauges are reading correctly and the gauge fuse is fine. Thanks.
Old Sep 30, 2003 | 11:20 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Doward here... was the ECU or battery ever disconnected? I think our IAC's have to 're learn' themselves... drive steadily along at 55mph for about 20 minutes or so, I think is what the instructions with my new one said...
Old Sep 30, 2003 | 11:26 PM
pasky's Avatar
Heya Doward, yea that is what happened, I forgot about the computer relearning itself, suppose I could take a trip out of town tomorrow and turn around, just gotta make sure to do it during ht eday, can't see my speed with the gauge lights out. Hope that is what it is. Whats with the new member name?
Old Sep 30, 2003 | 11:28 PM
vortex's Avatar
Engine: 5.0
I'm at the shop at Vortex's place (shop.. eh... it's a covered slab of concrete - but has the essentials. Tools, a cold fridge, and plenty of cold ones!) and on his computer.
Just doing some surfing, before I crash, and tackle the turbo in the morning.
Try the trip, see what it does!
Old Sep 30, 2003 | 11:29 PM
BitchinRS's Avatar
Yes they do need to re-learn. If I remeber correctly you need to do slow steady excelerations for about 5 or 10 min then drive like you normally do for another 10 min. It may stumble a bit at first but if you pay attention you will notice it getting better as it learns. I will look it up to make sure tomarrow and post agin.
Old Sep 30, 2003 | 11:30 PM
pasky's Avatar
Ok, definatley give it a try. Anyone have a clue about my gauge lights?
Old Sep 30, 2003 | 11:32 PM
pasky's Avatar
Oh, the dummy lights are working, brights, SES, blinkers, they all work, just the guage indicator lights and my shift light is not functioning, I already changed my headlight switch like 2 weeks ago.
Old Oct 2, 2003 | 02:00 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
My ECU must be pretty smart...I only have to accelerate up to 40 , and then stop and it's fine. i have reset the computer a lot because of general engine work, and when I first start the car, it idles like crap, but once I hit 40, even for a second, it's happy again. hmmmmm...
Old Oct 2, 2003 | 02:05 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
pasky: could be a fuse I had that happen to me alot.. Try turning on you lights and see if you tail tights are working... When I blow the fuse for my Gauge lights my tail lights go out...
Old Oct 2, 2003 | 12:58 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
At 40-45 mph the ECU completely closes the IAC valve and resets itself based on the newfound zero point.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
