Any way to test the Fuel pressure regulator
Old Sep 19, 2003 | 11:09 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Well...I think the title says it all. I still burn rich as you can really smell it sometimes.
Old Sep 19, 2003 | 11:13 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Ok, I'm making this up as I go along...but I think it's a pretty viable way to test the sucker! Buy a fuel pressure gauge and a vacuum pump. Hook the pressure gauge up to the Schrader valve and see what your fuel pressure is at at idle, with vacuum. Then kill the car and remove the vacuum line from the regulator, and attach the vacuum pump. Start the car and see what pressure it reads with zero vacuum. SHOULD be drastically higher. Start pumping that vacuum pump and watch the gauge...see if the pressure starts going down. Once you pump it up to around 18 or 20 hg's of vacuum, I figure you should probably be back to about the same idle pressure as it was with the car's vacuum connector on...
Tell me if that works!!
Old Sep 19, 2003 | 11:33 PM
if only i had a vaccuum guage/pump
Old Sep 19, 2003 | 11:56 PM
Nixon1's Avatar
They're like $20 or $25 at the local Advance/Autozone. But you can at least check the pressure WITH the vacuum connector on and then WITHOUT and see how much that varies. At least you'll know that the vaucum diaphragm is working then. The pump would only aid in seeing how WELL it's working.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
