underdrive pulleys w/ system
Old Oct 1, 2003 | 08:42 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
ok, im thinking of underdrive pulleys. i think getting the alt. pulley wouldnt spin the alternator fast enough to charge the battery. i have a 600 watt amp and 2 10 inch subs. would just the crank pulley be ok to run on my car w/o having charging problems at idle? i have a 94 3.4L coming for it this week too, what is the output on that alternator and would it help at all to use it?
Old Oct 1, 2003 | 09:30 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I think you can run just the crank pulley and be fine with the charging system, it's just the alt pulley you have to watch out for. Gotta upgrade that alternator to run the pulley. As long as your alt gauge reads 12 volts or higher at idle you're fine. If it's under, then it starts drawing from the battery.
Not sure how many amps the stock alt is.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
chrisandkristin
Car Audio
May 11, 2001 02:24 AM
