View Poll Results: What should I do about the collapsed lifter?
Screw Dyno Day... Do it right the first time - cam kit, port/polish heads, new valve springs, etc
17
85.00%
Need numbers now! Trying pulling apart a lifter, and replacing the guts with a new lifter! Just don't forget to replace that pushrod!
15.00%
Voters: 20. You may not vote on this poll
Need your opinions (about the Turbo)
Old Oct 2, 2003 | 10:48 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I need your guy's opinions... torn between doing it one way, and missing out on Dyno Day (Well, vortex can bring the stang, since I already paid), or praying the whole way it stays together...
Old Oct 2, 2003 | 11:58 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
It ain't worth it. Besides, I don't know about most people here, but I lack respect for unreliable horsepower (hence why I scoff at nitrous) .. Build her so those ponies will be there any time you ask for 'em..
Old Oct 2, 2003 | 08:03 PM
Pats Toy's Avatar
If you are having problems with one lifter, chances are that the others are weak also, or the engine is having oiling flow problems.
Like many others on the board I am curious to see the results, but pushing a dyno run on a weakened engine could result in a blown engine.
Old Oct 2, 2003 | 08:53 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Theres just no point in getting false dyno numbers and risking killing ur engine
Old Oct 2, 2003 | 09:34 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
If something major is wrong like this, the engine won't last very long if you give it a quick fix. I say do it right so you'll enjoy your turbo for many days to come.
Old Oct 2, 2003 | 09:49 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
poll results speak for themselves
Old Oct 2, 2003 | 10:35 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
it can wait. the dyno will be there anytime you want to go. you dont want to take a chance at doing some serious damage to it. and your not going to get the results you really want as is.
Old Oct 3, 2003 | 08:43 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'm tossed between the two.
I would like to see turbo results w/o special heads, etc.
However, if the current heads are screwed, its not going to be running right anyway.
Old Oct 3, 2003 | 10:04 AM
Doward's Avatar
Yeah... so far it seems to be the better judgement winning out. Especially now... Vortex yanked the distributor, and found metal shavings on it... I'm thinking possibly from the rearmost lobe wiping out.
If so, cam = shot. That means now, the heads and intake are going to get redone, polished, and this cam put into it -
Melling MTC - 5 (pn CL-MTC-5 for $114 @ AutoZone)
Duration:
204º/214º @.050"
Lift:
Intake - .420"
Exhaust - .443"
Lobe Seperation Angle:
107º on the intake side
117º on the exhaust side.
That cam, and lifters, for $115? I'm all over it.
It also means, the 16g wheel is going into the turbo, and I'm porting the housing. I MAY go ahead and pull that O2 housing from it, and eliminate the 's' in the exhaust flow it's creating....
Old Oct 3, 2003 | 10:33 AM
devianb's Avatar
I say screw the dyno day too because you can have your car dynod at any time. Bhp numbers from your turbod' 2.8l would be nice to hear, but I think you have more important things to do other than the dyno.
Old Oct 3, 2003 | 11:46 AM
jeremy178's Avatar
Car: '89 Camaro RS
don't push an engine with a weakened valvetrain, you'll regret it (I speak from experience)
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
Jlanz55
Sep 29, 2015 08:55 AM
