Cylinder Pressure
Old Oct 4, 2003 | 03:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Cylinder Pressure
What is the optimal cylinder pressure for the 2.8 at TDC? I would prefer that this be listed in PSI, please.
(This is specifically aimed right at KED85 since he has done this before)
Old Oct 4, 2003 | 06:40 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
with a compression tester, you should be able to get a reading of about 160 PSI +/- 5% on all cylinders.
Old Oct 4, 2003 | 07:47 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Thanks a bunch. Now just have to go out and get a tester...
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 4, 2015 07:11 AM
