ignition timing
Old Oct 14, 2003 | 04:57 PM
SharpSnake's Avatar
ignition timing
hello i have a 90 firebird with a 3.1 v6 mpfi and my timing acording to the hood says 10`before tdc when my engine was cold it was 14`btdc and as it wamed up it went way off didn't even show up on the timing tab on the engine so i was wounding if there is a connector i am suppost to take off so i can default time it or just time it the way it is but turning the distributor
thanks p.s. its nice to have a place to ask questions
Old Oct 14, 2003 | 05:58 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Disconnect ESC connector, under hood, passenger's side, on main wiring harness near distributor, on firewall, tan wire, black connector poking out of harness with black clippy disconnect thing.
Also, at the top right of this page, under all the silly advertising stuff that keeps this site running, you'll notice a row of tabs.. the second one from the far right is labelled 'search' ... next time you have a question this simple, please CLICK on it rather than making us type out this common info for the umpteenth time. Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
