help with my car and engine swaping
Old Nov 6, 2003 | 01:57 AM
RS1989's Avatar
Car: 1989 RS Camaro
Engine: V6 2.8 liter
Transmission: manual
i currently have the 173 2.8 liter v6, and im looking to put in a 350 small block, and i am just wondering if there is any way possible to fit it into a 1989 RS Camaro, and also if it is possible then where wan i find a cheap nice 350 enging block
Old Nov 6, 2003 | 02:06 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
You can fit the 350 in there, what do you think the IROC-Z TPI came with??? Yes, it did also come with a 305, but they are the same physical size. For more info on this swap, check out the engine swap forum. Also, swapping from a V6 to a V8 is going to be VERY involved. You will have to get a new trans, radiator, computer, front suspension, and a whole bunch of other stuff. The swap of choice for most of us V6'ers the 3.4 is the best bang for the buck. You can use the search button near the top of the screen and find the 3.4 swap boogie. It'll tell you everything you need to know and many members have used that as the 3.4 swap bible. Good luck...and BTW, welcome to the boards.
Jeff
Old Nov 6, 2003 | 09:18 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
2.8 boy covered just about everything needing to be said. The Small Block Chevy is essentially going to be the same dimensions despite displacement, so you can use a 305,307,327,350,355,383 etc. And all will bolt into placei n your car as if you had a v8 in there. The inherent problem is the transmission, something that drives the price of v8 swaps up is the fact that you also have to include buying a new transmission for the project, this really is probably a more exagerated problem than an actual one, since good v8 tranny's are in bone yards here and there and everywhere and can probably be had for around 100 bux, another 350-400 bux to have it rebuilt at a respectable shop. Think i paid 800 with the guys dropping the trans from my car themselves, rebuilding it, and reinstalling it with a vette servo and a trans go kit, also holds better line pressure (larger boost valve). Hopefully the area that you're in isn't emissions controlled, if so your swap options have just got narrower and your swap harder. IF you're in a smog controlled area, expect to use an engien from your model year vehicle or newer, then also expect to put in the computer and wiring harness along with all necessary emission sensors. So, if your not smogged, go carb, go v8, ditch computer and wiring if feesable, redo what ya got and have soem fun. But it'll still be a lil bit of work, don't ever get us wrong.
and welcome to the boards also .
Old Nov 15, 2003 | 09:47 PM
Akshay's Avatar
I think you should consider getting a custom supercharger. You can probably get injectors, fuel pump, MAP, etc. from the v8 thirdgens.
That'll be really cool. If your successful, do a write-up, and we can follow in your footsteps.
Akshay
Old Nov 15, 2003 | 10:27 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
You gonna need alot of stuff... So my advice is get a camaro or firebird w/ a V8 that the body is shot on or something, as long as the drive train is still good. And just transplant it over.. It would be alot cheaper that way... Thats what I plan on doing.. But I want to add a few more "goodies" to it...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
