My car make a weird sound when accelerating...
Old Nov 18, 2003 | 07:40 AM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
When I press on the gaz, I now hear a sound kinda like a baby that is crying or whatever... Is it the alternator? How much it cost to get replaced? Is there any model or I can take an original replacement? Thanks
Old Nov 18, 2003 | 08:53 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
You say you hear it when you accelerate, but is this only when the engine is under load? crying, or wining sounds are often belts, although the brushes in the alternator will give a similar sound if they're failing . Try making the same sound by popping hte hood and moving the throttle, then see if you can findout exactly where it's coming from.
Old Nov 18, 2003 | 09:07 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I hear it only when I hit the gaz pedal a little, when I don't touch It, I don't hear it... I already changed my serpentine belt this summer. I have a 1989 Firebird 2.8L auto
Old Nov 18, 2003 | 12:33 PM
BitchinRS's Avatar
Could be the tensioner (SP?). Mine screamed when the spring wore out.
BTW: it's gas. gaz makes you look like wanabie gang banger. It's just annoying to me to see z used as an s.
Old Nov 18, 2003 | 02:34 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Hey bitch I speak french all day long so don't be too rude
Old Nov 18, 2003 | 05:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! Hey my friends tell me that when I say "gas" it sounds like I say "Gaz"... go figure. Anyway, did you try revv'ing the engine from under the hood? Don't get caught in the belts (hair/clothing/jewelry/etc), of course...
Old Nov 18, 2003 | 06:37 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I just did it, I hear the sound I heard from the inside, I'm 99% sure it's the alternator now. Thanks for the help and bitching all...
Old Nov 19, 2003 | 10:48 AM
BitchinRS's Avatar
Hey how did you know my name? Wait...
If you want to make absolutly sure it is comming from the alt. use 3 - 4 foot section of a broom handle and put it on the alt and your ear on the other end. It will help isolate the sound. Or get a mechanics stethoscope. You can get them for about $5 and work better.
Old Nov 19, 2003 | 11:47 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
It could be an injector. I know when I put my intake back on the one time I didn't push the fuel rail down enough and it sounded like a horrible screaming sound.
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
midias
Aug 22, 2015 01:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
