car is making my ANGRY
Old Nov 25, 2003 | 09:53 AM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
ok why the hell is my freakin car leaking antifreeze from behind my heater and radio on the passenger side. GRRRR i'm really angry at my car and my trany makes wierd noises and there is this bump evry time i accelerate. i dunno i'm really tired of fixing things on this car.
Old Nov 25, 2003 | 10:15 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
wow, i think i've got the answers to both of your problems...wonder if i'll be the first to respond....
your coolant issue is a result of your heater core (if it's leaking in the cabin, which i'm assuming it is) when the heat is on do the windows fog up? and when it's off (if it's leaking bad enough) do they fog still?
The tranny makes funny noises and you get a bump...Fix = don't accelerate hard until you get time to fix it, and replace the tranny mount. It's a lil rubber thingie that's located on the back of the transmission, when the slip, your transmission will literally not be attached to the frame and is hitting the underside of the car....BOY DO I HATE THAT FEELING. Be nice to it until you get it fixed, they're cheap and easy...look for ked85's article about the heater core, even gave part numbers and prices for ya.
Old Nov 25, 2003 | 10:22 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
he said it. heater core and trans mount.
not counting the time to get the car in the air, a total noob should be able to do a trans mount in about 10mins... seriously. and the part is really cheap too.
the heater core can be easily bypassed if you need to drive the car now, but you wont have heat.
to bypass it, there are 2 hoses that go into the firewall..... get a $4 heater hose fix kit, or make one yourself... you need 2 hose clamps, and a barbed fitting that fits the two hoses to each other.
connect the hoses to each other..... thats it to bypass it..
if you do a search, you'll find better directions on replacing the heater core then i will ever type out... there may be a artical on doing it on the front page... not sure on that though.
Old Nov 25, 2003 | 01:31 PM
DAN_92RS's Avatar
Car: 92 camaro RS
Engine: 3.1L v6
thanx for your help guys .... i dunno when i'll have time to fix these things and its winter so i dont think i wanna bypass my heater . i'm going to try and fix it this week hopefully
Old Nov 25, 2003 | 04:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A heater core usually gives sign of impending doom before it leaks bad. You will notice that allot of times after you have driven your car and goto get back into it a while later, the windows are foggy, misted over.
Of course your is obvious but the foggy Windows is a sign of doom.
Heater cores are no fun to change. Might wanna try one of them lighter plug in heaters and by pass it, unless you have a nice warm place to work.
Old Nov 26, 2003 | 09:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
all i can say is take car of the heater core on a saturday morning cus getting the dash off is a b@#$@ and the tranny mount again won't be to hard
Old Nov 29, 2003 | 02:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Think about going to http://www.summitracing.com and ordering yourself part # <a href="http://store.summitracing.com/partdetail.asp?part=ENS%2D3%2D1108R&view=2047">ENS-3-1108R</a> . That's a polyurethane trans mount, and it'll last you forever. I went through three $10 stock rubber mounts in 3 years. Then I put the poly trans mount on back in 1997, and guess what, I'm still on the same mount! Plus you'll get yourself a free Summit catalog, too.
(You can get the free summit catalog without ordering, too- you can do it thru the website at http://www.summitracing.com/store_bin/freecatalog/ )
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
z28addict8490
Aug 7, 2015 08:48 PM
