Distributor Rebuild Question
Old Nov 25, 2003 | 08:29 PM
zoomzoom's Avatar
I’m about to replace the ICM and pick-up coil on my ’90 3.1 and was wondering about the following procedure:
Originally posted by TomP
I prefer to check & adjust the gap between the reluctor and the pole pieces with a valve feeler gauge. Adjust them as close as possible WITHOUT TOUCHING. Before you do so, spin the distributor gear; it'll probably spin without resistance. Then adjust the gap. Then spin the distributor gear again- you should "feel" the magnetic pulses very strongly; meaning, you "helped" by fixing the gaps.
I’m not planning on pulling the distributor during this repair (so spinning the distributor gear by hand is not possible, I'm planning to just use a remote switch & "tap" the starter) ‘cause I really need to get this thing running ASAP but I’m planning to do it in the future.
My questions are:
1) What’s a good ballpark figure to use with the feeler gauge? (.050 .075 .1 etc.) since I won't be able to feel the magnetic pulses.
2) What part do I actually bend to get the right clearance, is it the pole piece??
3) Will the distributor shims for a Small Block Chevy work for this application? I’ve tried to get some for a 3.1 from the local parts stores and they don’t list them. (This is for future use, when I actually do pull the distributor.)
ThanX for the help
:hail: :hail: :hail:
Old Nov 25, 2003 | 09:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
1. As close as possible w/o hitting. equal spacing all around.
2. The "fingers" sticking up
3. Distributor shims??
Old Nov 25, 2003 | 11:23 PM
zoomzoom's Avatar
Thanks for 1 & 2, as far as the shims, they are used between the gear & housing to remove end play. I've done that before on the Small Blocks & from reading previous posts I know some of the board members have done it to their 60° V6's. I just can't find anyone locally that has them for the 60° V6's.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
hokis
Aug 9, 2015 03:57 PM
