Does this mean I need a fuel pump?
Old Nov 26, 2003 | 06:27 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
I put my hands on the hump right behind the back seats and i can feel a strong vibration as well as low and high pitch noises. I got a dynomax superturbo muffler which gives this low deep tone at low rpms, is that it or is it or is it something else? I also noticed it does it mostly when im on D, neutral seems to be fine. Oh Im algo getting the check engine light when i leave the car running on P for a while, I think its related to Idle control or something like that.
thanks for your helps guys
Old Nov 26, 2003 | 06:39 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
only way an OBD 1 SES light could indicate a fuel pump problem would be with a fuel trim lean code
check your fuel pressure
should be 42 PSI
Old Nov 26, 2003 | 11:29 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
what code's (if any)is it throwing at you?
Old Nov 27, 2003 | 05:15 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you want to know all there is to know about testing your fuelpump view this threadhttps://www.thirdgen.org/techbb2/sho...hreadid=211664
Old Nov 29, 2003 | 02:10 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Before my first replacement pump died, it became extremely loud- sounded like a hornet's nest inside the fuel tank.
But when my original stock pump died, it died quietly- the steady "hummm" when turning the key to "on" turned into a sickly "gurgle/sputter".
When my current (second replacement) pump dies, not only will I curse out borg-warner, but I'll be sure to tell you guys what kind of noise it made. I'd probably be censored for the noises I'll make when the next pump dies.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
