Stupid woodruff key (in the crank)
Old Dec 6, 2003 | 07:59 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I can't get the old one out of the 2.8.
Anyone have a part number for Napa or something, or know where I can get a new one? I was gonna get one from Autozone, but they only have these little ones. Will they work?
Old Dec 6, 2003 | 11:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Got a pic of it? I might be able to help, I think.
Old Dec 7, 2003 | 06:55 AM
ede's Avatar
ede
key will come out with a hammer and chisle real easy. any machine shop or farm supply would have a new key.
Old Dec 7, 2003 | 03:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Hammer and punch the same diameter as the key is wide would work too, with less nicking of the shaft surface.
Or, if you're really mad at the thing for being stuck in there, a decent set of vise grips would work wonders, but you have to put the jaws on the ends of the key, not the sides...
Old Dec 7, 2003 | 10:02 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Someone tell me what the heck a "woodruff key" is. Is this some term someone made up?
Old Dec 8, 2003 | 07:32 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, there are two (that I've worked with, anyways) types of keys that are used in shafts to hold things in a certain position, like the flywheel on a lawnmower engine (standard key) or there are ones that are used to hold a gear or pulley on a shaft in a certain position, these having the same shape on one side as the standard key (square/rectangular), but have to be mounted deeper into the shaft for more holding power at high speeds, so they have a half-moon shape to them from the side. That is a woodruff key.
Old Dec 8, 2003 | 12:02 PM
JoshDT91's Avatar
Engine: 2.8L V6
Ahh ok thanks for the explaination that makes more sense to me. I've seen them before but never heard them called that.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
sahlomonic
Sep 20, 2015 07:15 PM
383cam
Sep 9, 2015 06:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
