Shifting Issues
Old Dec 19, 2003 | 09:25 AM
Christerray's Avatar
Car: 1986 Camaro
Engine: 2.8 V6
Transmission: Automatic
Shifting Issues
Alright, when I'm driving my camaro on the highway, and I give it WOT, it seems to just keep revving all the way to redline, without switching into a higher gear. I also might not have all my vacuum lines set up (I have this one vacuum line that goes into the intake, it's sort of like a big stopper, goes into a thin wire, and than ends with a little nub. It didn't start unless something was blocking air entering the nub, so I put a screw in there for now). What could be the problem?
Old Dec 19, 2003 | 10:05 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
700r4 is not vacume controlled.
Sounds like high gear is gone. Mine didnt have 3rd or 4th, clutch packs were bad.
Old Dec 19, 2003 | 03:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When you let off the gas, does it shift into 3rd? My original GM trans did that for about a year, and then it died. Only way to fix that is with a rebuild.
Old Dec 19, 2003 | 05:46 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
it will not go into 4th at WOT if that's what you mean. the "kickdown" cable will make it drop into 3rd gear, passing gear, and then it will not go back into 4th, OD, until i think its 75% throttle or less.
jklein337
Sep 19, 2018 06:23 PM
someone972
Aug 30, 2015 12:52 AM
crazynights
Aug 21, 2015 06:53 AM
Bryan F
Aug 18, 2015 02:28 PM
dhonda200
Aug 11, 2015 11:50 PM
