2.8 is out
Old Dec 31, 2003 | 08:14 AM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
2.8 is out
hey i took my 2.8 out of my 83 fireibrd. i just want to know,while it is out, should i put any aftermarket parts in it and if so what should i get. i already know i want to put headers on it if i ever find any and i want to keep it smog legal. also does anyone know any websites to get parts for a v6 from becasue it is really hard to find all the parts i want in one place. thanks Eric
Old Dec 31, 2003 | 08:16 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Cam, timing chain set, check the bearings, new high vol oil pump, clean up the heads, new gaskets....
Just what I'd do, while it's out. If a stick shift, replace the clutch!
Old Dec 31, 2003 | 09:23 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
depends on how much money/time you have.
1. Timing chain for sure!
2. cam, up to you.
3. Rebuild/replace the carb.
4. install an oil pump for a 93-95 3.4l, it is better then one you have, resonably priced. Slightly higher volume, better pickup.
5. replace oil pan gasket, valver cover gaskets, check rear main seal.
6. If you have alot of time, and some money, good connections, install the heads from an mpfi version 2.8/3.1/3.4. Valves are larger.
Old Dec 31, 2003 | 09:51 AM
ejm's Avatar
ejm
Engine: Carbed 350
thanks for the replies. probaly going to do those except the heads. my next project is going to be another car with a 350 and that is where i going to put all the serious power but until then a need a good v6. about the carb would i be able to get a 4 barrel or is that going to be too much gas going in. if i do get a 4 barrel i would mosty like upgrade the ingition somehow.what about carb spacers and intake manifold? would they help with out upgrading the vales,pistons and all the other really deep stuff?thanks Eric
Old Dec 31, 2003 | 10:56 AM
Dale's Avatar
Engine: 350 S-TPI
If you plan on doing another car for the power, save the money and stick with a 2bar.
Would need whole new intake, gaskets, mes with distrib, bla bla bla, then might as well do heads while your halfway their, bla bla bla. You know how it goes
I would attempt to upgrade ignition now anyways, will help now.
Dont forget to check/adjust timing once done with chain.
Old Jan 1, 2004 | 11:36 AM
icebird_1981's Avatar
u have a LC1 engine right, there is a supercharger u could get for it or u can built it to take the spray.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
