Tach clarification please...
Old Jan 5, 2004 | 09:38 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
My 1987 bird has the ugly gauges with the quater sized dummy lights. To put in a tach setup, do I have to go through all the hassle of pulling computers and trannies to go to an 86 and OLDER tach setup? Should I just wait for an 87 and up setup (I'm in no rush)?
Old Jan 5, 2004 | 09:42 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I would swap the dash harness and cluster for one in the same 2-3 87-89 year period of your car, and one with the options you want.
It can be done, it will be a huge PITA, and you will hate your car halfway through the procedure.
Old Jan 5, 2004 | 09:44 PM
sixbanger's Avatar
Is it still a pain swapping in one from an 87 and up?
Old Jan 5, 2004 | 09:59 PM
V6sucker's Avatar
Engine: blown up
well, for compatibilites sake, I would not go above 90, as the 90 dash is completely different.
I would stick to 87-89, swapping the harnes is basically the same no matter the year(as long as it's the same sub generation- IE 82-86 87-89 90-92), it's a PITA. Not neccesarily the actual harness swap, but taking the dash apart/back togeather is the pain.
My freinds 89 had a tach, so they are out there and exist, just finding a good cluster and more importantly the harness is the hard part.
Old Jan 5, 2004 | 10:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Swapping from an 85 Full gauge cluster to an 88 Full gauge cluster (yes, gauges are in different places for some reason, & 2 less VSS wires) wasn't tooooo difficult, except those damn back lights
Old Jan 5, 2004 | 10:39 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I believe that 86 firebirds and above have electronic speedo's while the 85 firebirds and below had mechanical speedo's. Might be wrong, but!!
The Trickster!!!!!!!!
Old Jan 6, 2004 | 12:23 AM
Engine: 5.7 / 7.4
You're correct. I have an extra cable flopping around now, but that all right, gonna keep people guessing
Old Jan 6, 2004 | 03:44 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Originally posted by Project: 85 2.8 bird
...gonna keep people guessing
People, as in the next person who owns your car? Ya right dude, you own a V6 Camaro, you own it till it dies!
edit: Sorry Project, I know what kind of car you drive. But you get the idea.
Old Jan 6, 2004 | 06:18 AM
Engine: 5.7 / 7.4
Camaro????
edit: Oh, I see the source of the confusion. I keep putting in engines from Camaros into it.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
